Question about Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi
After installation my starter has been replaced twice (within 2 months)- the only 2 times I used the stop button
  • james kappers
    james kappers May 11, 2010
    does the start still stay engaged when you press the stop button?
It is installed wrong went thru start every 4 months for 2 years till they figured it out. Go to a dealer and have them check it out. That was my problem.
Posted on Mar 04, 2009
    Novelist:
  • 152 Answers
It is possible that the Tach/RPM monitor circuit (an integrated system that informs the RSM [remote starter module] that the engine has started and is running) is malfunctioning or is not properly connected, hence the continuous effort of the RSM to start an engine that is already running, causing damage to the cars starter and possibly other circuits and/or wiring.
Return the car to the installer and have diagnostics ran on the Tach/RPM monitor circuit.
Your system may have a hardware or programing choice that will allow you to decide between a  tached or tachless operation, depending on the model that is installed.
I hope this helps... Good luck
Posted on Feb 23, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
My 1999 Chrysler 300m has had two starter fires. Replaced starter twice in 6 months help!
Yes sir. The ignition switch/relay is not releasing the "start" connection when key is released after starting thereby solenoid remains on with stater running. If threr is a relay check and replace if necessary. If it's got no relay replace ignition switch.
Dec 14, 2012 | Chrysler 300M Cars & Trucks
My preinstalled remote starter on my truck has a combination/sequence that the dealers salesman could not get roght bit twice to start pickup. im looking for fimiliar combination/sequences that my seem to...
If you have to press the vehicle's door lock AND the remote starter button...something is definitely wrong with the installation. If the prestige is a one button unit, try pressing the button twice within two seconds to start vehicle (press...thousand one, release, press...thousand two,release) this is the default setting.
Aug 05, 2012 | Prestige Remote Start
1992 gt 750 starter clutch total rebuild with new parts still slipping
I had the starter clutch out on my '81 '7 750 LTD twice. The first time I rebuilt and it lasted 6 months. The second time I rebuilt there was no improvement. I bought a used one on e-bay, installed it and it works like a charm.
Aug 07, 2011 | 1992 kawasaki GT 750
I have a Starter Brand Watch that did not come with a manual. I can't seem to get the chime to stop chiming on the hour.
Just bought a STARTER Sport Watch Model# STW14 @Walmart
TO CHANGE TIME:
1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
Sep 12, 2009 | Bulova Watch
Does anyone have instructions for Nike Imara Fit WR0076?
How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
PLEASE READ CAREFULLY
STEP 1:
First hold the button for set/light.
STEP 2:
wait for the "hold to set" message to appear
once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
STEP 3:
To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
*If you are done setting the time press the set/light button, and there you have it.
If you still need to change the minutes of your digital watch proceed to step four.
STEP 4:
After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
To set MINUTE:
press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
*If you are done setting the minute, press the set/light button, and there you have it.
If you still need to change the date specifically, the day of your watch proceed to step five.
STEP 5:
To set date, specifically, DAY:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
*If you are done setting the day, press the set/light button, and there you have it.
If you still need to change the date specifically, the month of your watch proceed to step six.
STEP 6:
To set date, specifically MONTH:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
To set MONTH:
press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
*If you are done setting the month, press the set/light button, and there you have it.
If you still need to change the date specifically, the year of your watch proceed to step seven.
STEP 7:
To set date, specifically YEAR:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
*If you are done setting the year, press the set/light button, and there you have it.
If you still need to change the 12/24 hour format of your watch proceed to step eight.
STEP 8:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
*If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
If you still need to change the power hour of your watch proceed to step nine.
STEP 9:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
Press set/light to set POWER HOUR.
May 13, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
How do I set the time for nike imara fit WR0076-002 wrist watch?
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
Mar 26, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
I dont know how to set the time
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
Nov 11, 2008 | Nike Imara Run WR0075-014 Wrist Watch
Setting the date and time on watch
time:
hold left button -- hour will appear and begin flashing.
press right button to set.
press left button to advance to minutes, press right to set.
date:
press left -- date will appear. now hold left until day flashes.
press right to set.
press left to advance to month, right to set. then same again for year.
Nov 11, 2008 | Nike Imara Soar WR0103 201 wristwatch
Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Logo
218 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
