Apple for iMac Motherboard
Problem for Apple (661-2795) for iMac Motherboard
17" iMac quit working
By te_kelly on Feb 22, 2009
When I took the iMac to a dealer they said it was the motherboard and it would take $1,000 to repair.  When I got home I let the computer in the garage.  Next morning I brought the computer in and plugged it in.  The computer worked, for about 10mins, until it heated and then it quit again.  Now I am wondering if it is the motherboard or something else.
Best Solution
posted on May 07, 2009
Very Helpful)
colt_baldwin
Rank: Wiz
Rating: 85%, 21 votes
Your Imac may be one of those affected by Apples purchase of inferior capacitators from Taiwan. If you are less than 3 years from the purchase date, apple will repair the problem for you for free. Just take the unit to your nearest local Apple Genius or tech. If you are outside of the repair extension guidelines, I have provided a link here which can show you or someone more skilled how to repair the problem. Ordering a new motherboard and power supply will set you back a lot of money, however the following guide and pdf give you step by step instructions on how to ressurrect your dead imac without speding more than $100.00. I was able to repair my imac using this guide and it was worth it to save a $2k computer that was only 3 1/2 years old. Check it out:
the following information (in italics and bold)  is taken directly from: http://www.jimwarholic.com/2008/07/how-to-repair-apple-imac-g5.php.  (this site is complete with instructions, manual and the full compliment of materials available at an extremely affordable and fair price. I took a chance and repaired my own, it is not as hard as it sounds1)
The iMac G5 Repair Extension Program for Video and Power Issues applies to first generation iMac G5 computers that have video or power-related issues as a result of a specific component failure. If your iMac G5 is exhibiting any of the symptoms listed below and your computer's serial number is within the noted ranges, your computer may be eligible for repair, free of charge. If Apple or an Apple Authorized Service Provider (AASP) determines that your iMac G5 computer is eligible as part of the program, the repair will be covered by Apple for up to three years from the original date of purchase even if your iMac G5 is out of warranty.
This is a worldwide Apple program.
Affected systems will exhibit one of the following video- or power-related symptoms:
Scrambled or distorted video
No video
No power
Note: If your iMac G5 is not experiencing any of these symptoms, you do not have to contact Apple or any Apple Authorized Service Provider.
Which iMac G5 computers are affected by the iMac G5 Repair Extension Program for Video and Power Issues?
The program is available for certain first generation iMac G5 models that were sold between approximately September 2004 and June 2005 featuring 17- and 20-inch displays with 1.6GHz and 1.8GHz G5 processors.
The affected iMac G5 computers have serial numbers where the first 5 digits fall into the ranges noted below.
Serial Number ranges:
W8435xxxxxx - W8522xxxxxx
QP435xxxxxx - QP522xxxxxx
CK435xxxxxx - CK522xxxxxx
YD435xxxxxx - YD522xxxxxx
Some second generation iMac G5 computers have serial numbers that fall within the upper band of the ranges listed below. Only first generation iMac G5 computers are affected by this program.
Where do I find the serial number of my iMac G5?
The 11-digit serial number is located on a label under the foot of the iMac G5. There is a bar code underneath the serial number.
To view the label, hold the sides of the iMac and gently lay the computer face down on a soft, clean towel or cloth.
Is the iMac G5 Repair Extension program available for other Apple computers?
This program applies only to the systems noted in this FAQ. Other versions of the iMac G5 line are not part of this program. Click here for more information on how to identify iMac G5 models
Free guide for how to repair the motherboard capacitors, rescue the hard drive and more.
http://www.jimwarholic.com/docs/Repairing-Apple-iMac-G5-Motherboard.pdf
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Feb 22, 2009
Helpful)
leecom72
Rank: Guru
Rating: 89%, 2543 votes
Hi there.
It sounds to me like the machine is overheating, this can of course damage the motherboard but in most cases its just a build up of dust inside the case or the CPU (processor) fan has failed, a can of compressed air directed at the air vents and fan can in most cases solve the problem.
Good luck and thanks for using Fixya!!!
Was this helpful?
Yes
No
Solution #3
posted on Oct 29, 2009
Not Rated)
matteink
Rank: Apprentice
Rating: 0%, 0 votes
iMac crashesafter about 1 hour. iStat shows Hard drive about 47 degrees. Sometimes takes a long time to start. Hardware test shows alert 4sns/1/40000000:tp0p-131.000
Was this helpful?
Yes
No
Popular Solutions for Apple for iMac Motherboard
Questions and Unsolved Problems for Apple for iMac Motherboard
Do you recommend Apple (661-2795) for iMac Motherboard?
Answer
Answer
Can not communicate with the PLC devicenet module. I think the DN is not setup correct in the Power... (More)
Answer
everything fires up but no video and I have tried swapping several cards
Answer
powers on screen dead wont light up the dvd rom flashes off and on an makes ticking noise from the... (More)
Answer
hi have a dv8225nr laptop. did bios upgarde to fix keybroad problem after download restarted laptop... (More)
Answer
I need a screw location replacement guide to put my motherboard back in. It is an early 17"... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboards Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
