Question about Sony Playstation 3 (PS3) Console
Video won't show on my on my tv-PS3
I have all the cables and wires hooked up properly to my tv, but nothing will show up. I know its not the video cables because i turned up the volume on my tv to see if i could hear the menu, but i couldnt. Also, i cant turn on my tv with my controller. The 4 lights just flash.
  • 60 Answers
Can you get cable/sat. feed or dvd on your tv.......if not thers a problem with the tv......try unplugging tv if no pic comes through for about an hour....yes i said an hour this will reset tv back to factory default when you pulled it out of box.....if this does not work you might have to call a repair man
Posted on Feb 23, 2009
  • mike mcardle Feb 23, 2009
    also try holding the power button down for 5 sec then release this will reset video settings
I unhooked my PS3 from one tv and now another tv recognizes it but has no picture or sound. bought new wires and still nothing. what is my next step?
Try resetting the video output settings. They may not be appropriate for your new tv.
Press and hold the power button until you hear two beeps while it is off.
Jun 14, 2014 | Sony Playstation 3 (PS3) Console
I have a ps3 60gb capatible for the ps2 I have it hooked up to the TV but its not showing anything on the TV I have the High Def connectors for the TV
It is a known problem with some high def connectors not working properly. The following should be checked before concluding there is a problem
1. Ensure you have your TV tuned to the right output station for as your ps3 is connected.(for example you cannot have your ps3 connected to the second set of av ports on your tv and your tv is on av1, it has to be on av2)
2. Cross-check the functionality of your ps3 using the default av cables that come with it so as to know if your cable or console is faulty.
3. Ensure that you high-def cables are properly connected.
If all the above prove abortive, you have to see a repairer to check-up your ps3 or tv
Dec 25, 2010 | Sony PlayStation® 3 (60 GB) Console
I switched my ps3 to a new tv and cant get it to work. I reset it to rest the video feed but it still will not bring up anything. i is like nothing is connecte to the tv. i have checked and rechecked the...
If ur ps3 console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
click here to download ps3 repair guide
Dec 21, 2010 | Sony Playstation 3 (PS3) Console
Nothing shows on screen when inserting game , i hear the disc is turning but nothing shows on screen
Make sure you have the cables hooked up properly, regardless of whether your using an HDMI cable or regular A/V cables.
Best thing to do in a case like this is to do a factory reset on your PS3. Be sure that the A/V cables are being used originally and are hooked up properly.
Here is how to do the factory reset on a PS3:
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Try that, if you still don't get video and you know the cables and the TV are set to the right output then its an issue with the main board not having any output.
Apr 22, 2010 | Sony Playstation 3 (PS3) Console
No video output
for the ps3 i know why u are not gettin any video. make sure the ps3 is off with the red light showeing in the front then hold down the power button for (i think) 30 sec. u will see the light blink a bunch of times them you might have to re start it but it should show the vedeo againg
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
No dvi pictur showin up on my plasma tv
try a lower video output resolution on your PS3
Nov 09, 2009 | Gateway GTW-P42M303 42 in. Plasma...
No display on my Ps3
Two or more things, first make sure you have your audio vidio cables correct
Yellow= Video
Red= Audio right
White Audio left
Also make sure that the tv matches the input your cables are connected into. I would make sure the restart the PS3 to make sure the video is good (after checking the tv input)
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
Surround sound not working with PS3..
hook your front speaker wires up to the A side and on the front of it make sure only the A speakers are playing but leave the rear speakers plugged into the B side then hit the listen mode button and you should be rocking
Apr 24, 2009 | Kenwood VR-407 Receiver
No video - blue screen...
since you bought this console used, it maybe set to HDMI 1080p/ 1080i/720p output(by the original owner) and if your TV does not support this there will be no picture, the only way to lower the output resoloution is to get into the options menu but to do that you will need a freind with a tv that supports whatever resoloution its been set too.
Mar 13, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
108 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
