Question about Jenn-Air JLG7130A
Grill model 720-0163 need to convert from propane to natural gas
Would like to run the grill off the natural gas that comes into my home
  • 8,197 Answers
Go to jenn airs web site an order a new natural gas regulator and or-faces.
Good luck and please rate fixya!
Posted on Feb 24, 2009
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Can i use natural gas connection with thermos model 461246804
Some grills can be converted. You may have to contact Thermos regarding this.
Sep 02, 2014 | Grilling
I have a kenmore ellite bbq model 141.16691 propane - I want to convert to natural gas, there is no conversion kit to make it but the natural gas model 141.17691 is exactly the same - just natural gas. If...
Many manufacturers make grills in propane and natural gas, but are not convertible from one gas type to another. The reason being safety. Each grill model, whether it's Natural Gas or Propane is tested and approved for that one specific gas type and that alone. Converting it would put all the responsibility on you, if something was to go wrong.
I suspect in part, the reason you want to convert is so that you want have to refill the propane tank any longer. But, you may want to consider this against convenience. Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Which boils down to lower high end temperatures, longer preheating times and the expense of running an approved gas line to the grill for Natural Gas. Not to mention the cost conversion parts.
But, the decision is yours to make. Thanks for choosing FixYa.
Aug 06, 2011 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Need to convert our Q300 propane grill to natural gas. Do you sell conversion kits?
Unfortunately, Weber grills are not convertible from one gas type to another. There are no conversion kits available for your model or any Weber model gas grill.
To confirm this, go to the following link and on page 2 under Warnings, last paragraph, left hand column, you can confirm this, if you like.
http://help.weber.com/manuals/pdf_files_2011/Gas/Weber%20Q/Q300320_OwnersGuide_41060_021011.pdf
The only advantage to converting it to Natural Gas is not having to refill the grill tank. The downside, is that you will loose the heating capability that Propane has. It burns cleaner and hotter than Natural gas, in an outdoor environment.
Hope this helped you. Happy Grilling!!
Jul 13, 2011 | Weber Q300 Grill
I have a grill Frigidaire FD27LKEC 27 it is running with natural gas and I would like to convert it to propan. Is there a convertion kit or what do I need to change.
At one time, there was a conversion kit available to convert your model from Natural Gas to Propane Gas. Unfortunately, it is no longer available and has been removed from the retail market. This, usually happens, when a problem resulted from a conversion of one gas type to another.
May 23, 2011 | Frigidaire FD27LKEC (LP) Grill
Can a weber spirit e210 natural gas grill be converted to LP gas? I won the grill but don't have natural gas at my home
Weber sells conversion kits. Basically, you need a new regulator and manifold to accommodate LP instead of the existing regulator/manifold setup for natural gas. Unfortunately, Weber does not sell their parts online. Their parts phone # is: 877-731-8081
Apr 27, 2011 | Weber SPIRIT E-210 (NG)
What is the NATURAL gas flow rating CFM for a Weber Genesis S-330 grill at 60,000 BTU max? I will be using 1/2" black pipe 40ft long run to the grill off a 3/4" main line - ok? Thanks...Dennis
Dennis, it's not the CFM you need to know, it's the water column inch that is required. In this case it's 7 inches. Also, if you're burying this 40' run, you can't use black iron pipe. A less labor intensive and perhaps less expensive way to go is 1/2" Flexible Copper Refrigerant Tubing. It's comes in 50' & 100 ' roles from your local home center. Even if you're not burying the line, it's a better way to go, as you'll have fewer fittings that could be prone to leaking. I
n addition, you'll also need and an inline gas shut off valve at the connection before the grill and a 12' long quick disconnect gas hose, that connects to the copper pipe connection at the shut off valve and then to the grill. This is a code requirement.
Now, with all this said, I hope you have a Genesis S-330 Natural Gas Grill. Because, the Genesis Propane Grills ARE NOT convertible to Natural Gas. And Genesis Natural Grills ARE NOT convertible to Propane.
Hope all this helped you make the right decisions. Have a great day and Happy Grilling!
Apr 13, 2011 | Weber Grilling
I have a Turbo Elite 3 burner barbecue. Want to convert it from propane to natural gas. Where can I get a conversion kit?
Your best bet is BBQ's Galore. Since it's their grill, if there is a conversion kit for that model, they'll have it. However, not all gas grills are convertible from one gas type to another.
Apr 01, 2011 | Grilling
Converion kit to natural gas.
I don't believe Weber makes a gas conversion kit for your model grill. I say this, because your model grill comes two ways, Natural Gas or Propane. This indicates to me, that there's more than just changing the burner orifices involved.
I can tell you this ... If you could convert it to Natural Gas, you would soon discover that the grill doesn't preheat as fast as with propane. Nor, will it maintain heat as well as propane, in an outdoor environment. Propane burns cleaner and hotter than Natural Gas in an outdoor environment.
Sure, it may seem like a hassle to refill and change the tank, but I can assure you, you won't be satisfied with it's performance.
Feb 03, 2011 | Weber Spirit? E-310 Propane Grill
Converting Thermos Stainless Grill to natural gas
You have to install a conversion kit for it to work the way you want. The reason is because the orifice in either the valves or the main "jet" that feeds the burner tube has to be changed. Natural gas is really not as efficient as lp gas (propane) because it takes more natural gas to create the same btu output as propane.
In short, your grill will not work if you do not do the conversion. I am including a link that lists the conversion kit for your grill, you can order it there and you can download the assembly manual as well.
Here is the link: http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1723&CategoryID=25
Nov 20, 2009 | Thermos Stainless Steel Gas Grill
Grilling Logo
686 people viewed this question
Top Jenn-Air Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
