Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't figure out how to finalize, I record fine but can't find anything to finalize it, I have no manual, thanks for any help. Magnavox MWR20V6 Jim
  • Anonymous Mar 01, 2009
    I have the same problem, I hooked a camcorder to it and burned a dvd, but it wouldn't play in another dvd player. When I go to edit there is no button to finalize it. The recorder is a Magnavox MWR20V6, I have no manuel anymore.
  • oshinsd Apr 12, 2009
    my finalize button is greyed out and it won't let me get to it, what can I do?
Insert the dvd you want to finalize. When the menu loads press Stop and then press Setup on your remote control. Scroll down to disc edit and press the Enter or OK button. You should see the word Finalize there, select it and then it will ask to Finalize Yes or No. Select Yes and it should finalize your disc perfectly and play on any player.
Posted on Mar 13, 2009
    Problem Solver:
After you are finish taping then hit the stop button,and it will finalize,but you have to wait a few seconds for it to do this.
Posted on Apr 01, 2009
How can i finalize after just a few minutes recording
As long as there is sufficient space on the disc to store the finalization data. Press Setup, then select Disc Edit (up/down arrows) and press OK. Then choose Finalize and again press OK. You will see a confirmation window, select Yes and press OK again. Wait for the finalization to complete.
The manual is available here: http://www.funai-corp.com/6pdf/om/MWR20V6.pdf . See page 37 for the screen captures.
I hope this helps.
I hope this helps.
Feb 19, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox DVD/VCR Recorder ZV457MG9 How do I finalize my DVD on this player/recorder?
http://www.ehow.com/how_8623235_do-finalize-magnavox-dvd.html is how to finalize a disk on Magnovoz! I have the ZV457MG9 - its model takes with
1) loading disk
2) select the set up button
3) select DVD edit
4) select finalize DVD
Then you finalize the DVD!!!
Jan 31, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My disc records fine, plays great on the Magnavox, but no other player can read the disc?
You must finalize a disc before it can play on other machines. Please refer to your documentation for how to finalize a disc.
Jan 11, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dont know how to finalize dvd after recording on magnavox vcr/dvd
You can find a copy of the manual on the web link provided here:http://tv.manualsonline.com/manuals/mfg/magnavox/mwr20v6_1.html Print a pdf copy for yourself. If you need more help the customer care for you dvd/vcr player is at this telephone number. 1-800-605-8453 give them the model number of your dvd/vcr unit and they will be able to help you. I hope this information helps you with your problem.
May 10, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dubbed DVDs will not play
You have to use the Magnavox dual to finalize the discs, and then they should be able to play on other players. I don't have a manual for that exact recorder, but in general you would go to the Settings Menu of the DVD player --> go to Disc Edit --> and then select Finalize - the exact pathway might be a bit different on that particular recorder. Once you have finalized one of your discs, try it on another DVD player and see if it works. Good luck!
-Tha Mp3 Doctor
Feb 15, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox DVD recorder...finalizing problem
The manual isn't too helpful either - "Recording error other than below," it says. There are a couple of possibilities. The Philips/Magnavox/Funai recorders automatically record in VR mode when you use +R discs (there are two possible recording modes - V Mode and VR Mode). Is it possible that you have switched disc types lately? If you are currently using -R discs, switch to +R and vice versa. The manual states that +/-RW discs take a while to initialize.
I couldn't find a full factory reset on that one, so you may have to unplug the unit for about 20 minutes to restore all the defaults.
Another possibility: Finalization requires some extra space on the disc. If you accidentally pressed the button that changes the recording format between SP, EP, LP, etc., you may not be able to fit the same amount of video on the disc that you were able to fit before. You can change the format by pressing the Disc Mode button on the remote - LP Mode will fit 3 hours worth of recordings onto a 2-hr disc and is considered a "medium quality" recording. Try changing the Disc Mode to LP and see if it will finalize the next disc that you record. The downside of this possibility is that the discs that you have already made that are giving you errors are not "fixable" - you will will have to re-record the shows to a new disc in LP mode.
-Tha Mp3 Doctor
Feb 11, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox MWR20V6 problem
on my magnavox mwr20v6 i cant record my vhs to dvd i get black screen every time and my DVD are new and I just open my magnavox after a long long time and ecsup for get my VHS record to DVD it is fine I would like to fix this issue :(
Jan 01, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Transfer VHS to DVD
The illustrations within the PDF is very help!
To play disc in other DVD players…
The disc needs to be finalized.
Page 37 of the manual has “Finalizing a disc”.
Recording from DVD to VCR…
Page 39 “Dubbing Mode”
http://www.funai-corp.com/support/manuals.aspx
Type in the box: MWR20V6
Nov 09, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Unable to record/dvd recorder problems mwr20v6 phillips
I also have same problem and have had no luck with anything I have tried
Aug 11, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
654 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
