Question about Singer CE-100 Futura Computerized Sewing Machine
Singer 5932. Needle timing is messed up.
Needle hits the rotating ring thingy, instead of passing thru at the appropriate place. How do you reset the timing on this beast?
  • M Nelson
    M Nelson Apr 14, 2009
    FYI: Without diagrams or pictures, this was very frustrating and difficult................................................................................................................................................................but it worked, so thank you! bye
bargainbox
  • 1388 Answers
SOURCE: Needle hitting bobbin plate
Is the needle inserted correctly with the flat side at the rear and fully up into the holder ?
If yes, take off the needleplate, remove bobbin case and slowly rotate the handwheel towards you watching the relationship between needle, and the "hook" of the moving "race".
Set on wide zig zag........when the needle is fractionally past it's lowest point, and starting to rise, the hook should be level with the left side of the needle when on the right hand stitch of the zig...the eye of the needle will be below the hook, and ready for thread to be picked up for the stitch to form.
Any other result will mean your timing needs adjusting.
Posted on Feb 10, 2008
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
  • 980 Answers
SOURCE: singer 760 needle breaking
You need to retime the machine, if you email me I will attaqch timing instructions, drivewithken@blueyonder.co.uk
Posted on May 19, 2009
bargainbox
  • 1388 Answers
SOURCE: singer 7426 timing off
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Posted on Aug 27, 2009
Testimonial: "very helpful...thank you"
  • 40 Answers
SOURCE: My Singer 5932 is skipping stitches
try changing the needle. if it has hit, it may be bent.
Posted on Jun 01, 2010
I have a singer sewing machine 5932. it will not pick up its thread from bobbin. it will not sew. i have checked everything i know . i know a little about sewing machines.
Try installing a brand new needle. Confirm it is installed facing the correct direction in the machine. A bent/.damaged needle or one that is installed incorrectly frequently will not pick up the bobbin thread.
If you've confirmed it's correct and still doesn't pick up the bobbin thread, then it's likely the machine has been knocked out of time, ie the needle and hook are out of sync. Search for sewing machine timing or take it for service.
Feb 27, 2018 | Singer Sewing Machines
My singer 5932 auto bobbin winder is not working?
Make sure that something like your buttonhole lever or button for a twin needle are not down (if you have them). You can get it fixed, but you can also just buy a Simplicity bobbin winder for under $25, that actually does a better job anyway.
Aug 18, 2014 | Singer Sewing Machines
Adjust the timing on a singer confidence quilter 7469q
Hook/needle timing needs a hands on guidance to get it fix, 2 options either you can watch in utube 'singer sewing machine hook timing' or 'google' for singer 7469q service manual for your referral.
Nov 10, 2013 | Singer Confidence 7469 Mechanical Sewing...
Needle hits the wheel under bobbin
Sounds like the toothed-belt (if there is one) jumped off timing. You can try realigning until the needle goes into the hole as the bobbin holder rotates in place. You can do this by manually slowly operating machine -- do not do with electric pedal.
Oct 08, 2012 | Singer CG590 Mechanical Sewing Machine
I have a Confidence 7470 purchased in May 2009. I was sewing tulle today and the thread kept snapping while sewing. I assumed it was catching in the tulle. The last time it snapped, the thread jammed in...
Sounds like your machine is off timing, When the machine is properly timed, you should see the hook passing behind the eye of the needle when the needle is on it's upward stroke. If this is not correct the machine will not pick up the bobbin thread. You may have to take it in for adjusting, unless your a bit machnical.
May 11, 2011 | SINGER 7470 Sewing Machine
Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Feb 16, 2010 | Singer Sewing Machines
Need manual to know how to set tension. Singer Sewing machine Mod.#5932 Serial#N319411147
Singer Machines are probably the easiest to set..
first thing you need to do is remove the thread..
Set you tension knob/wheel to the middle number.
When you rethread the machine, stop when you get to needle. Put the presser foot down and pull the thread. If it pulls hard then so far so good. If it pulls easily, the thread is not thru the tension wheel right. Thread the needle and stitch about 10 inches on a medium wt fabric.
The stitching should feel even on both sides. If the top still is tight, loosen it up just 1/2 number.
So, if your middle number is 4.5, turn it to 4. If it seems loose, turn it to 5.
Kelley
Apr 30, 2009 | Singer Sewing Machines
Singer CE-100 Futura Computerized Sewing Machine Logo
289 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
