Question about Emerson TC2556D TV
Emerson TC2556D HOW GET CLOSED CAPTION FEATURE?
I have the original remote and the tv works fine, but I can't figure out how to get closed captioning feature to work. i am sure it previously was configured and worked fine.
TTM77
  • 19 Answers
SOURCE: Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Posted on Aug 26, 2006
SOURCE: cant get closed caption feature back
I prayed to God for help & it worked!
Posted on Jan 25, 2008
On the universal remote hit the menu button then on the TV itself use the vol +/- to select and the channel +/- to move the it up and down. it that simple
Posted on Aug 12, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: I have a Emerson (LC3203MC)
If you have this TV connected to a cable box or satellite receiver, the captions may be coming from there. Some of these devices support captioning on their own, separate from the TV. Check the device setup to be sure captions are turned off.
Posted on Feb 14, 2010
freetek
  • 5568 Answers
SOURCE: My tv is an Emerson
I think Comcast doesn't know much about their equipment; their box has no influence on CC since it is embedded in the program material and is passed through their receiver to your set. There are two possibilities; the remote is no longer sending the pulse train to control CC or the set's receiver isn't responding to that command.
You can do a rough check on your remote if you own any kind of digital camera; still or video. Turn on the camera so that you have a display picture of the room you are in. Point the remote toward the camera's lens and push (and hold) a button on the remote that you know is working, such as the "Power" button while looking at the LCD display of the camera. You should be able to easily see the blinking of the InfraRed LED(s) which most all digital cameras can 'see.' Once you know what to look for, try the button that should control the Closed Caption function. If you don't see anything on your camera LCD display, that button (or the circuit it controls) isn't sending out the code train required to control that function. If that is the case, you may be able to buy an original ('universal' remotes really aren't) replacement remote from:
Remotes.com
Conversely, if you DO see the remote blinking, then the circuit in the TV set that responds to the CC (and others) command has partly failed and that is more costly to repair.
Posted on May 08, 2011
How do I get closed caption on the tv?
If the remote control is its original, there will be a button on it marked "CC". Press it to ON/OFF the closed caption. This is a toggle type button. http://electrohelponline.blogspot.com/
Oct 09, 2014 | Emerson EWF2704 TV
How to activate the sylvania 20 inch flat screen closed caption feature?
with the original remote enter the menu and look in settings for CC and then select CC1 which is the most commonly used one.
May 01, 2012 | Sylvania Televison & Video
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
Mar 10, 2011 | Element ELC-HS321 32 in. LCD TV
Cant turn off closed caption
sherrillbrom
With our VIP receiver models, you have an option to turn on/off closed caption through the receiver. Press the Menu button on the remote, which will display the Main Menu on the TV screen. Press 8 (Preferences) and then press 6 (Closed Caption). On the Closed Caption screen, press 1. On the Closed Caption On/Off screen, select CC Off and then press Done from the TV screen (using your DISH remote). This will turn the feature off on the receiver. Test to see if it is turned off by watching a program that has CC. If it still appears, then the feature is activated through your TV. Please refer to your TV manual to turn the feature off. I hope this helps.
Ray Calo
DISH Network
Feb 21, 2011 | Televison & Video
Closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage&dv=universalremote&md=jumboremote&kw=&st=&ar=&dt=&so=&pg=1&file=others/innovage/jumbo-manual.zip
Mar 28, 2009 | One For All URC-4330 Remote Control
How to remove closed caption from JVC TV without original remote
how can i get rid of the closed caption on my magnavox tv without the original remote
Mar 19, 2009 | JVC C-20810 TV
Closed captioning
I am sorry you don't. You will need the original remote. I have enclosed a link where you can see the original remote and order one if you want to. If you see the picture, there is a caption button on the remote to turn on and off the closed captions Good Luck. Here is the link http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS24424&brand_pn=SANYO_DS24424&mode=large&uid=11872683567810
Aug 16, 2007 | Sanyo DS24424 24" TV
Black rectangle on t.v. screen
It sounds like you have the Text feature on the closed caption option turned on. your going to most likly need an original remote to turn this feature off as far as i know of. If you do not have an original toshiba remote to turn off the clkosed caption or in some sets you have to go into the menu to turn this feature off, maybe you can borrow one from a friend that has one or you can get one from http://www.remotes.com. Good liuck and let us know if you need more assistance
Oct 05, 2006 | Toshiba 32A62 32" TV
Closed Captioned
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Televison & Video Logo
293 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
