Question about Microwave Ovens
Bulb replacement on Neff Microwave Oven
Please help with advice on how to replace the bulb on a Neff Microwave E No: H5430N0GB - Thank you
5 Suggested Answers
SOURCE: H7881 Neff Microwave Light Bulb type
go to the NEFF spares area here: http://bshappliancecare.com/Neff/neffspares.html at BSHAppliancecare - if you an locate the FD or E-Nr inside the appliance door then you are laughing. The site's a doddle to use. It should have exploded diagrams and part numbers to look up - and order. The prices seem to be fantastic for the replacements I've made (oven and fridge seals)
Posted on Jan 18, 2009
  • 75 Answers
SOURCE: Replacing light bulb in Microwave Oven.
if this is a counter top modle this is no problum, unplug it!!!
open door look for the light hole vents, ( that is where the bulb is )
you will need to unscrew the outer casing. noproblum there is nothing but reguler insalation in side and a area where the bulb is. replase it you can buy them at any hardware store,
if is a under cabinet there my be a axes door if not will need to take down,
hope this helps.
p.s. 1st time i that there was all kinds of things in side but not
Posted on Jan 23, 2009
  • 149 Answers
SOURCE: How to replace the bulb in our GE Microwave Oven,
the outter cover wrapes around unit remove screws, be careful high voltage is present even with power off just replace bulb reassemble
Posted on Jan 14, 2010
  • 17 Answers
SOURCE: replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Posted on Dec 01, 2010
Whirlpool oven g2p 62f ss
see the diagram attached, and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Jul 08, 2013 | Neff Microwave Ovens
How do I replace the light bulb in a NEFF H7860B1GB/01 ?
Unplug power first. You need to remve the screwa that hold the bulb cover, access the bulb and replace it, I will wee if I can find a diagram.
Oct 06, 2008 | Neff Microwave Ovens
I have a Kitchenaid combo unit of Oven & Microwave. Model YKEMC308KM01, Serial # XP4603281.Can someone help me as to how to change the light bulb of the microwave. I simply dont see any openings on the...
That's covered on page 21 of your owner's manual.
If for some reason you don't have yours, you can download it free here.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven.
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
You can find handy exploded views and order parts by model number here.
Dec 18, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
How do you replace the bulb please
take out the old bulb then put in the new one
Nov 29, 2010 | Neff H7871 Convection/Microwave Oven
Replace light bulb on the Neff H7871 combined oven and microwave.
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
Jan 13, 2010 | GE JE1590 Convection / Microwave Oven
Replace microwave light bulb
See page 24 of the owner's manual here:
Feb 06, 2009 | Amana AMV5206 Microwave Oven
Nov 15, 2008 | Microwave Ovens
Neff Combined oven and microwave
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Nov 03, 2008 | Neff H5470 Microwave Oven
Microwave Ovens Logo
138 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
