Question about GE 24 in. GSD4320Z Built-in Dishwasher
My dishwasher leaks from underneath directly in the center Model G E Permatuf M # GSD500G-01aw. Are there any solutions and the dishwasher is about 20 years old
My dish washer leaks from underneath
Posted on Feb 05, 2010
  • GE Master
  • 3,361 Answers
Seals are gone.
Replacement is the only answer.
Repair is not recommended.
Posted on Feb 22, 2009
My frigidaire dishwasher model #FFBD2403LW0B serial#TH13718959 leaks when it is running.seems to be leaking from underneath not from the front door.
how about putting the washer on some sort of stand so that you can look from underneath and then running it. use a light and observe where the leak is
Apr 11, 2017 | Frigidaire Dishwashers
Dishlex 302 leaks from underneath
Good Morning Friend,
This appears to be a UK Electrolux dishwasher; however, if you have a US Electrolux model, here are a few tips you can attempt to troubleshoot the issue: First, Use only fresh detergent designed for automatic dishwashers. Measure detergent carefully. Possibly try a different brand of detergent. Secondly, spilled rinse aid can cause foam and lead to overflowing. Wipe up any spills with a damp cloth. Lastly, check to see if your dishwasher is level. If your dishwasher is still leaking, after trying the above solutions, I suggest contacting the manufacturer for further assistance. Hope this is helpful.
-Best regards-
WP
May 19, 2014 | Electrolux 18 in. ESL4114 Slim-Line...
Samsung dishwasher leaking when not running
First, try to find the source of the leak. Leaks most often appear at the door of the dishwasher or underneath. Leaks can be caused by a number of issues: worn door gasket, water temperature, leaking drain hose, worn gaskets, or a corroded tub. For help identifying the cause and finding a solution, see the troubleshooting chart at Dishwater leaking for more information. Good luck!
Aug 17, 2012 | Samsung Dishwashers
EWDW6505GS0 Model Electrolux dishwasher 10 months in service has Error Code 01. Leak. What to do?
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Feb 14, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
I need the dimensions for GE dishwasher GSD500G. For fitting a replacement washer.
Under the counter dish washers are very standardized. Just measure the current counter height and width of the opening. Nearly everything will fit unless it's a special order. GSD500G install dimensions are available on-line. Just Google the Model Number.
Aug 02, 2009 | Dishwashers
Blowing domestic fuse towards the end of cycle.
Recommend your check the heating element that lives underneath the lower spray arm. It may be shorted directly rather then simply heating via resistance through the element.
When you post back, please provide the make and model number of your dishwasher.
Good Luck!
May 03, 2009 | Dishwashers
Open Questions:
See all GE 24 in. GSD4320Z Built-in Dishwasher Questions
GE 24 in. GSD4320Z Built-in Dishwasher Logo
483 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
