Question about Kenmore 24032\24036 Top Load Washer
Tub overflow I have a Kenmore top loader... I just replaced the fill switch but did not sove the problem. After I replaced the switch....ran the washer. It completed all cycles (ran great....) then when it completed all cycles it just started filling ..... filled the tub completely full, never shut off. I turned the water off just before it started to overflow.... Anybody got an idea ????
  • joemaher Feb 22, 2009
    The water cut off at the correct level throughout the running the cycles... the over fill came with the dial close (or on) off....
  • joemaher Feb 23, 2009
    Does this washer have any type of "emergency cut off" if the tub gets too full?
  • Kenmore Master
  • 3,361 Answers
Remove the hose from the water level switch and blow air through it.
The water level switch air hose has a clog in it.
Posted on Feb 22, 2009
  • steve
    steve Feb 22, 2009
    Replace the water inlet valve.
  • steve
    steve Feb 23, 2009
    NO. No emergency cutoff.
    The water inlet valve is the valve the water hoses connect to.
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Won't fill w/ water, Kenmore 3.5 Super Capacity Front Loader
The pressure switch is likely to blame. Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
No spinning or agitating
If it has a mechanical timer switch, (the main control knob) that is possibly the culprit. The timer switch is basically the "brain" of this type of washer. I had this problem on a washer.
Dec 26, 2008 | Kenmore 24032\24036 Top Load Washer
Font loader washer water does'nt shut off
remove top replace fill valve left rear be sure not to remove the screens inside valve except to clean but be sure to reinstall or trash may get into valve and not allow proper shutoff
Oct 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Top Loader
try different temp settings be sure screens in inlet valve end of hoses are clean and taps on all the way if you gave water to washer and still none coming in suspect bad fill valve
Sep 03, 2008 | Kenmore 24032\24036 Top Load Washer
Cycle stops...
replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
151 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
