Question about Orion Televison & Video
I have a small Orion TV, model TV 1334A. Everytime I move the darn thing I have to set it up again! Hope you have directions I can print out, this drives me nuts!!! I can't afford another TV right now. riverpopes@yahoo.com
    Genius:
  • Orion Master
  • 1,673 Answers
I have not worked on your model. I will answer genericaly:
If you are not used to doing TV service you will have to give the set to a TV service center to fix this.
On many of these types of sets on the main board or a daughter board there is a silver oxide battery that is like a calculator battery.
If you are able to work on the set, open it up and look for this battery. If there is a battery in your set, take note of the number on it. You can get one and then replace it.
If your set is a model that does not use a battery, there are two other ways memory is held. Some models use a gold leaf capacitor. It will take TV service experience to be able to locate and change this capacitor. This type of cap would be a special order from a parts supplier.
The other method is they store the setup in an EPROM. In this case the EPROM or the uPC can have a fault. In this case servicing the set would be not feasible.
Jerry G.
Posted on Feb 23, 2009
What causes the vertical lines to appear on the top of my screen. I have a 19" orion.(tv1929) The picture jumps at first, but will settle after a few minutes. The lines never go away.
There are parts called capacitors in the set's vertical output circuit that need to be replaced. The vertical output integrated circuit may also need replacement as well, since the bad caps can cause it to work overly hard. This is a pretty common problem, but I can't tell you specific part locations or values because I don't have a circuit diagram for this model. You might see if a service shop in your area (if there are any left!) can give an estimate for the repair. Or, given the low replacement cost for small TV sets, you might just use this as an excuse to buy a new small flat-screen model.
Sorry I can't be more specific, but maybe this will point you in the right direction. Thanks for using Fixya!
Jan 31, 2010 | Orion1934 19" TV
Lost manual, need set-up codes for an orion t.v. also need set up knowledge
Direct TV Orion codes (older tv codes are at beginning):
10236, 10463, 10179
Hope this helps somebody!
Oct 29, 2009 | Orion1934 19" TV
I have an Orion TV Mod TV1933b
Unfortunately, with most TVs this function is located only on the remote. If you could do it without the remote there would be a button on the panel of the TV labeled accordingly.
To purchase a replacement remote (a universal remote won't work with that model TV) call Fox International at 800-321-6993. They are the largest Orion parts distributor that I know. Orion doesn't sell parts directly to the public.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 11, 2009 | Orion1934 19" TV
Am i able to get into the menu of small orion tv without a remote
Try holding down both volume buttons on the front of the set. If the menu comes up use the the volume and channel buttons on the front of the set to navigate in the menu. I hope this helps you.
Mar 23, 2009 | Orion1934 19" TV
Looking for a good tv at a reasonable price
Brand new they run just over 200 dollars. But you may want to Google search these TVs. There seems to be a lot of trouble with them
Feb 20, 2009 | Orion1934 19" TV
Orion ftdv2004 is stuck on menu and can't get off manually
I may help? if you try unplugging the set from the mains supply for at least 2 hrs and then try again.
Jan 14, 2009 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
I need a remote code for a hitachi tv
Here is the setup copde page http://universal.dev.efocus.nl/?pag=54. I didn't see that model remote listed but many times the remote manufacturer will use the same codes.... So look at other remote codes for Hitachi and see which one works.
MM85
Jul 24, 2008 | One For All URC-3021 Remote Control
Orion tv codes
try these codes for the orion tv:0121,0135 or 0035. good luck
Nov 03, 2007 | Orion1934 19" TV
Orion standard tv
Have you had any kind of magnets close to the tv set? I had a brand new sanyo do the same thing. I had pulled the speaker box out of my truck and stood it up next to the tv (not thinking about where I put it). Turned it on a few hours later only to see a messed up picture. I moved the speaker box to get behind the tv and the picture got better. Moved the speaker box back to the truck and after a couple of days the picture was back to normal. These were 4 large magnets on these speakers. Maybe I helped some!
Mar 08, 2007 | Orion STV2763 27" TV
Televison & Video Logo
273 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
