Im trying to locate the fuse fro the fuel pump on my 2001 dodge stratus RT
Checked inside panel, and under hood for power distribution box, remove cover & map should be under cover. Usually close to battery.
It's likely located in the fuse panel in the engine compartment near the battery. not exactly sure which relay it is... if you are lucky it's marked on the inside bottom of the cover that you have to remove to get to the relays.
Robert
