Question about Ricoh Aficio 2027 Black and White Copier
Ricoh Aficio 2027 when scanning documents over 4 or 5 pages e-mail documents with no attachments, and pages of gibberish in the body of the e-mail. How do I fix this?
  • Anonymous Feb 23, 2009
    It should be, although for documents with large page counts it sends an e-mail with no attachment, but begins:
    This is a multi-part message in MIME format.
    --DC_BOUND_PRE_<1235350655.00007487e872>
    Content-Type: text/plain; charset=US-ASCII
    Content-Transfer-Encoding: 7bit
    This E-mail was sent from "RNP87E872" (Aficio 2027).
    Scan Date: 23.02.2009 08:57:35 (+0800)
    Content-Type: application/pdf; name="20090223085735931.pdf"
    Content-Transfer-Encoding: base64
    Content-Disposition: attachment;
    filename="20090223085735931.pdf"
    JVBERi0xLjMKJZKgoooKNCAwIG9iago8PC9UeXBlL1hPYmplY3QKL1N1YnR5cGUvSW1hZ2UK
    L1dpZHRoIDE2NjQKL0hlaWdodCAyMzM5Ci9CaXRzUGVyQ29tcG9uZW50IDEKL0NvbG9yU3Bh
    Y2UvRGV2aWNlR3JheQovRmlsdGVyWy9DQ0lUVEZheERlY29kZV0KL0RlY29kZVBhcm1zWzw8
    L0NvbHVtbnMgMTY2NCAvUm93cyAyMzM5Pj5dCi9MZW5ndGggMzE1NjAKPj4Kc3RyZWFtCgAW
    DUAFg1ABYNQAWDUAFg1ABYNQAWDUAFg1ABYNQAWDUAFg1ABYNQAWDUAFg1ABYNQAWDUAFg1A
    BYNQAWDUAFg1ABYNQAWDUAFg1ABYNQAWDUAFg1ABYNQAWDUAFg1ABYNQAWDUAFg1ABYNQAWD
    UAFg1ABYNQAWDUAFg1ABbcxVwsAFt8FLTHOSyAC2DBSFDHQ5lAMSJQAWwrGPyEqkJiTORIAC
    2FbhyGo8JFrSVQAWwXdnvQtkRGJYykqgAthOVof2GE2iDxpF7ZUC6UAC2NT5OthjdiuKxESZ
    VmQUcVaABbAZ8h/YZzhTFYPJIoksziEoALYQfPeh0hPF2dEtsWaeH1UAFsUPsdb1ZENxQLCW
    YQt1QNEoALY8+e6rSGmUk5kkM08lQSVQAWx9z2n6sawRQRJDEnkqVodKgALYy+2MqoCiRDyl
    DKqStIh0qAAti60P7KoCiRPhTGPViZiEBaoAC2IrtlkYlpBcItWYBjRDSVAAWw857LYxLOFM
    ZVNQFHCFspgAth97YVJJZgViKqCDQMs1QAFsD8LalJJZwViKqCMvleqAAtg1x/anJJZgRiHV
    F2EyvVAAWuaReH9k5JLMCReqi7VoqlQAFrmcXY+DW4kmswIxFXF9JlMqAArqE1BbBmOi9t9J
    LDBIvVReMfY1KgALXM8GnwfTWtJErBIvVRfA/sDlUAFrmeXTwPpLEkiWBcHVRfA+2B5IAC1z
    PLocy6REkkiWBYvVReAroxEgALXMoIYjIyTMVBi8CQO1YPA/oxkoALXM8Qnx8RkarGLztCsC
    4TqgkY55NkoALXM8HviFuMCsnQ5CmCwTqgkY5yuWAAWuZQPeT2zVgXkjG4FglpK9JTlEsgAt
    czxFEM9msB94cNQJBLWVxPPA2sgAtcz06H7xns1xvi0xrBdRa5OVx2IQ+tAAtczxHdXGkN8e
    uBwJKLQUHKMhp0PrYALXM+tD2depFPE96rAsFyZzEUQRVQZK0JgAtcz093XqY7hTfrwLBImG......
    with pages and pages more of this gibberish.
    I hope this hels. Thankyou.
  • Anonymous May 11, 2010
    Not sure what you mean...the scan to email should be an attachment - PDF? Are the actual PDF's in gibberish? what about scan to folder?
Try increasing the "max email size" -or turning it off all together.
I'm going by my own memory, so, you may have to do some browsing of settings, but I believe the setting is under: "User tools", "Scanner features", "send settings", (or some similar button under scanner features). There you should see a setting for Max. email size (or similar). The default is 2048kb.....try increasing it to whatever you want- maybe 4000-5000kb, and check the results.
Usually the machine will stop scanning when it reaches the max size, so I'm not sure if this is the problem, or if we are talking about very large files that actually exceed your emails capacity to allow an email of this size? How large are these files once scanned that you are talking about? What is your scanner's resolution set at? 200dpi is more than sufficient for text. You can check that at the same location as above only select "scan settings", "default settings". If resolution is set to 400 or 600 dpi the files will become MUCH larger than they need to be.
Hope this helps.
Posted on Feb 23, 2009
  • 48 Answers
I would try the easiest solution first. Make sure you have good pdf program such as adobe. Try opening the email in another pc with a clean copy of adobe before assuming it is the machines scan feature that is failing.
Posted on Jan 16, 2010
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Have a printer/scanner that does not scan the documents in the same order they are scanned in...it changes them from the least amount of pages to the most....want to set up to keep the same as scanned...
are you scanning to email or folder ? what are you viewing the scanned docs with ? it sounds more with what you are viewing the docs with look for header of date and click it it should be newest to oldest date.
May 24, 2010 | Ricoh Aficio 2027 Black and White Copier
Scanning
this is a long process, if the machine is on the network, you can access the on board ram by typinjg in the address of the machine into your web browser. From there you need to enter the admin area, top left of page. Enter: admin, press the tab key twice and you should be in. From there you need to set up an address for the copier to scan to: this is done through the address book and you need to select SMB and then enter in the path to the PC
Aug 13, 2009 | Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh Adicio on a mac
Your machine requires the Postscript option installed in order to print from your Mac. The printer is printing gibberish because it cannot understand the postscript driver from the Mac. .
Jul 22, 2009 | Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh aficio 2027 print/scan module addition
you need to go into the sp mode and turn the NIC unit on and make sure the USB is off. Won't work until you do.
Apr 21, 2009 | Ricoh Aficio 2027 All-In-One Laser Printer
On Ricoh Aficio 2027 say error SC 873, the machine print by her self
Needs to delete e-mail data in the hard drive sp5-832-008 Enter service mode and run this sp mode
Oct 07, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
User Manual
hi
u can download manuals from the below link
PDF file
http://www.ricoh-usa.com/downloads/manuals/bw/aficio2022-27.pdf
Jun 18, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh Aficio 2027 Black and White Copier Logo
1,643 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
