Question about Peg Perego Milano XL Stroller
I cannot close milano stroller
I just cannot close milano stroller. Could you help me? Do you have this stroller manual? Tks a lot !
  • 1 more comment
  • tangi Mar 16, 2009
    please help
    I have the same problem
  • dbroderick Apr 06, 2009
    My Peg Perego Milano stroller will not collapse. Any suggestions on how to fix it? Does anyone have an owners manual?
I read the answers written here and I can see why some people are still confused. So I will try to break it down into steps:
1. With your foot press down on the lever numbered 1 at the bottom of the stroller. This lever holds in place.
2. With your foot press down on the the lever numbered 2 at the bottom of the stroller. Hold this lever down with your foot because it does not lock in like lever numbered 1.
3. While your foot is still pressed on lever number 2, hold the handle bar with both hands and **** it forward. This step is rather tricky. So think of it as punching both hands forward horizontally while holding the handle bars.
At this point the stroller will come apart and fold. Now if you see that the stroller is stuck in position and does not fold or comes apart only with a lot of force then you have to oil the joints. Use WD-40 and spray it on the joints on the side of the stroller located right below where it say "PegPerego" on the body of stroller. That is where the joint where the stroller folds is located.
Hope this helps.
Posted on May 29, 2010
I should note, you have to twist the thing on the center of the handle bar to make the handle bar go back. Press levers "1" and "2" and it should fold up like a dream. If not, you need to oil the parts.
Posted on Sep 22, 2009
If you have the kind that has levers at the bottom numbered "1" and "2" you just have to push those down and then pull the big handle. if it still doesn't work try spraying a little DW-40 on the levers or some Pam cooking spray if you don't have any DW-40. we got a super old one and it worked for us and it runs great! :)
Posted on Sep 21, 2009
  • Jeff Bean Oct 31, 2011
    As noted by the folks preceding, it mainly needs lubrication. I used Pam (to avoid the WD-40 odor - thank you sarahwitt!) to lube the two foot levers and the sliders that the foot levers move. The real problem is the plastic cam that the sliders release up near the point where the handle connects at each side. These small crescent shaped plastic "C-clips" are what actually holds the stroller together while you don't want it to collapse, and you need to spray your lube into where they rotate, and then work it in so that they rotate almost freely. After I did that, everything seems to work much better.
  • 29 Answers
Contact Peg Perego. They will email you a copy for free.
www.pegperego.com
Phone 800-671-1701
Posted on Mar 17, 2009
How do you close a very old peg per ego Milano
Please contact Peg Perego for assistance
Sep 28, 2014 | Baby Gear
Peg perego milano stroller
Here is peg perego's list of stroller manuals but I don't see Milano, there must be a different model name somewhere on the stroller. I will keep digging.
Mar 03, 2008 | Baby Gear
I removed them to wash forgot how to replace them
If you contact Peg Perego directly, they can mail or email you a copy of the manual for this stroller, which should have instructions and diagrams showing you how to put the straps back on.
www.pegperego.com
Phone 800-671-1701
I hope this is helpful. If so, please remember to give me positive feedback!
May 05, 2011 | Peg Perego Milano XL Stroller
How dou you fit the Prego Infant Car seat (without the base) into a Prego Stroller (Milano?)?
There should be pegs under the seat cover that you pull ot than turn the carseat towards you and click it on the stroller.
Jul 15, 2009 | Peg Perego Baby Gear
Are you able to get replacement seat/back for a milano model per perago stroller--ours needs to be replaced
yes. Peg perego has a warehouse in canada... our stroller came with a manual that had an orderform for replacement parts.
Jun 30, 2009 | Baby Gear
Above the wheels at the rear of pram there are small levers that you must activate. I'm pretty sure you press the left one first (do not need to hold down) then hold down the opposite side's lever and push forward and down on the handle of the pram. If this doesn't work try pressing the levers in the opposite way first. Originally the pram would have had stickers "1" and "2" on the levers to dirict you how to fold. If in Oz look up Karisles on google and follow the prompts to download instruction manual.
May 28, 2009 | Peg Perego Milano XL Stroller
How do you close the milano
Standing behind the stroller when you look down towards the basket, look along the frame, just above the rear "step" on the right side you will see a plastic lever that usually has the number one on it, step on it. On the other side you will see an identical lever that usually has a number 2 on it, step on it, while holding it down with your foot, pull up slightly on the handle bar then push down and back to you at the same time. The stroller will fold and you lock it in place by taking the oblong shaped rings attached to the handle bar and hooking them over the "pegs" on the side of the stroller near the bumper bar.
Mar 19, 2009 | Peg Perego Venezia Single MT Blu Moon...
Shoulder harness
Contact Peg Perego & they will give you answers over the phone or send you a manual for free (email or snail mail).
800-671-1701
Aug 31, 2008 | Peg Perego Milano XL Stroller
Peg perego Milano XL stroller hood
Peg Perego
LINK: http://www.pegperego.com/page.php?sid=adbdaeb9e5e15cdd9498e53c732b46b7&pageid=UCGRP009&dwt=IS&dwf=05
For residents of USA and Mexico only.
3625 Independence Drive
Fort Wayne, IN 46808
Main Office: (260) 482-8191
Office Hours: Monday - Friday 7:30am to 4:30pm EST
USA Customer Service Hours:
Monday - Friday
8:00am to 8:30pm EST
USA Infant & Toddler Product Customer Service: (800) 671-1701
USA Ride-On Vehicle Customer Service: (800) 728-2108
USA Spanish-Speaking Customer Service: (800) 225-1558
USA Customer Service Fax: (260) 471-6332
USA Customer Service Email: CLICK HERE
MEXICO Servicio Al Cliente: 01-800-710-1369
Jan 06, 2008 | Peg Perego Venezia Single MT Blu Moon...
Peg Perego Milano XL Stroller Logo
1,359 people viewed this question
Top Peg Perego Baby Gear Experts
Jennifer Rock
Jennifer Rock
romney2012
Are you a Peg Perego Baby Gear Expert? Answer questions, earn points and help others
