Is this an antenna problem the antenna is touching the tire carrier. I had no problems when the antenna was on the roof, but that was a magnet antenna, this one is a whip.
First you need to check your swr it should be a max of 3 to 3 or the unit will shut down the amplifier. if the antana is touching any metal it will thow the swr off if it is running paralell to metal on the vehical will also thow the swr off your bes bet is get it as hi as you can and as far from the body and assories of the vehical as you can.
