Question about Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw
Where do i connect the blue wire on the carburator
  • 181 Answers
There is no blue wire on the carb.it should go to shut off switch
Posted on Feb 23, 2009
Toyota Camry 2003 V6 radio
2006 Toyota Camry Car Audio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jun 16, 2016 | Toyota Cars & Trucks
I have a 460 international gas tractor. Have rebuilt the engine and replaced wiring and carburator but will not start. What could be the reasons?
Go back over the wiring you connected and make sure all connections are hooked up check for spark at the plug,check fuel is getting to manifold
Oct 03, 2015 | Garden
My Honda Met.2 Chf50 runs great with handkerchief on intake of carb but when you attach breather quits
Hi, Monte the two wires are probably for the electric auto choke for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Troubleshooting
Carburetor Tear Down And Cleaning 2005 Honda Metropolitan CHF50 Scooter
Honda Metropolitan Jazz Ruckus Resource page
Honda 2003 NPS50 Ruckus Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CHF50 2007 Metropolitan Owner Manual
Jun 11, 2017 | 2005 Honda Metropolitan Base
When i rev up it cuts out and blows out blue smoke
Blue smoke is usually indicative of poor air/fuel mixture (carburator problem) or incomplete combustion. The carburator probably has dirt in the main jet. You can try fuel system cleaner, but you'll most likely have to clean the jet (requires some disassembly of the carburator). Could also be something as simple as a dirty air filter.
Jun 16, 2011 | 2007 Generic Ideo 50
Hello there,when i starts z car in z morning,blue smoke comes out.Is that normal please.And z car miss fires if i accelerate suddenly.I have changed z distributor,spark plugs n wires.Z car is of carburator...
The blue smoke is OIL, coming from bad seals in the valves. It drains into the cylinders overnight and when you start the car it burns the oil off. This is probably fouling your plugs and if backfiring will fould the carburator. The miss firing is due to the age and most likely the timing of your engine, along with fouled plugs and carb.
Mar 08, 2011 | Honda Accord Cars & Trucks
The 4 wheeler wants to start but in don't its like its not getting gas to carburator
clean your carburator, check sparkplag, observe if its making a good electrick supply by kicking kickstarter blue lightning is good.
Jul 27, 2009 | 2007 TN'G Baja 150
The start/fast/stop wire isnt connected to the engine Where do I connect to??? Help
The wire should be "Z" shaped on the end and connect to a lever on the carburator, the wire shieth needs to be anchored close to that area.
Apr 25, 2009 | Garden
Idleling of 1984 F250 Ford PU
mcdevito75, That carb, solonoid most likely works with both, electricity and vacum, That blue wire should hook up to that solonoid, look at the plug ans solonoid and see if there"s a point for the wire. If it has broken off yo"ll have to replace the solonoid. Also have the choke system on your truck checked out, if the choke is not operateing as it should this too can cause your problem. Have your local repair shop take a look.
Dec 04, 2008 | 1984 Ford F 250
1987 ford f350 7.5L 460cc carburator wiring diagram
The wiring harness is different for a carburated truck. You can get the wiring books from the dealer, or try to find it on line.
Jun 18, 2008 | 1987 Ford F 350
Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
