Question about Samsung Syncmaster 730B 17" Flat Panel LCD Monitor
Monitor; Power light on, screen blank - Samsung Syncmaster 730B 17" Flat Panel LCD Monitor
    Novelist:
  • 180 Answers
Do you have a second monitor you can switch out? Have you checked the monitor itself to make sure it's not set for digital vs. analog (or vice-versa)? Are all cables and plugs tight and secure? Has the brightness level been turned down? These are all the troubleshooting steps I go through before anything else. There are just a few things that generally go wrong with a monitor. Since the power light is on, that rules out one of them. In this case, I'd narrow it down to the power inverter or the backlight for the screen has gone bad. The best way to check for the backlight is turn off all the lights in the room (preferably at night) and see if you can detect even the faintest of an image on the screen. If so, you know the backlight is out.
The bad news is no matter how you look at it, it's probably time for a new screen if none of the troubleshooting did anything. The good news is- monitors are cheap and geting cheaper. Shoot- I just saw CompUSA.com had a 25" monitor for $199 this week. Almost got one but I'm afraid my wife would divorce me if I brought in yet another. Guess I'll have to wait till she needs to change the prescription on her glasses first.
Let me know if there is anything else I can help with.
Posted on Feb 23, 2009
Gateway blank screen
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 04, 2014 | Gateway Computers & Internet
Screen goes bank after 2 seconds even if powder light is on
i just finished repairing a 20 inch acer monitor that had the same issue.... you have to take it apart and examine the power supply side of the monitor. there are capacitors that go bad on that board. you can tell be feeling the tops of them... the feel rounded. replace the capacitors and put it back together and it will work fine
Apr 16, 2009 | Computers & Internet
Blank screen
This looks like a problem with the video card or the power supply to the monitor. Try connecting a different monitor and if you still face the same problem then probably you may need to have a look at your video card or its connection in motherboard
Feb 01, 2009 | ViewSonic A90f+ 19" CRT Monitor
Monitor screens blanks a few seconds after I switch on computer
Took the cable connecting the monitor to the computer and reversed it, this seems to have worked!
Dec 21, 2008 | Sony SDM-S74 17" LCD Monitor
Pc does start but monitor is blank but its light is on
What connection are u using? DVI to DVI? VGA to VGA? or are u using DVI+ adapter to change the source to VGA?
Nov 21, 2008 | LG L1717S-BN 17" LCD Monitor
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Blank screen
its cheap buy a good one!!!!!!
Dec 22, 2007 | Computers & Internet
Blank Screen..Will not power off
The flash light test only works with lcd monitor as they have back lights. Double check the connections again, also, if you can borrow a monitor try it on your pc, it may be your graphics driver needs to be uninstalled and re-installed, but you will need a monitor to see.
Dec 13, 2006 | Proview PS 776 Monitor
Screen goes blank
Hi jkm007, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 12, 2006 | Videoseven V7 L19PS 19" LCD Monitor
Samsung Syncmaster 730B 17" Flat Panel LCD Monitor Logo
270 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
