Question about Netopia (3347NWG-ENT) Router (3347NWGENT)
I have Netopia 3347-02 but i have a Wireless Error help!!!
I have Netopia 3347-02 but it doesn't want to enable wireless mode and the wireless light on the Netopia is blinking. so i did a self modern test and it says "Self Modem Test Failed! Wireless Error". so how do i fix this? please help!!!!!
  • juandaniel12 Feb 27, 2009
    ok i rested the modem and upated the the firmware but didnt work. so what do i do next.
  • Ved Pradhan May 11, 2010
    hmm.
    so the wireless part is not working what you can do is you can reset the modem as well as upgrade the firmware of the modem,
    try a hard and let me know..
    vedhick
    Scholar:
  • 62 Answers
As im sure you found out the hard way, you have to swap the netopia out. You must've really snapped your lucky fingers for that one. I do this stuff all the time for a living, and I've never seen a Netopia not function correctly, a new one that is from your ISP anyway. Did you get the netopia from your ISP? or did you buy it on E-Bay, or Amazon.com, a netopia from another ISP wont function properly, but the wireless still should.
Bad modem, just swap it out. Its under warranty, its a new modem, that model number just came out last year. You wont even get charge for it. Its just frustrating when new equipment fails, and unfortuanatly, its becoming more and more common place it seems. Don't even get me started on my new motherboards from ASUS.
If its not a project, its no fun, right?...hehe
spin
Posted on May 01, 2009
How do i turn off the wireless on my netopia 2247nwg router
Type 192.168.1.254 Enter your password default Username-Admin Pass-Admin
Once in there find your wireless setting and turn it off. I personally do not have a netopia router but these are the usual steps, if you have any problems comment back and i will be glad to help.
Mar 20, 2010 | Netopia 2247NWG-VGx Wireless Router...
Wireless not working, went into setup and enabled
1. Please make sure its the router and not the laptop. can you get the laptop to scan for other networks . this is to make sure that the issue is with the router and not the laptop. 2. goto the setup again and try changing channels to 11 or 4.
Thanks
Ranjit
Oct 05, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Netopia 3347 wg not giving wireless signal. its ok when connected directly. was working ok last week. Q6
This is a problem with the routers firmware so to correct this better do a firmware upgrade with this unit and you can get the firmware from the manufacturer....
Sep 15, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Getting PS3 NAT type 2 with Netopia router!
u should have dmz on router. but if not u can try your modem. that was my issue. i still use router for connection and stuff but i enables ip/dmz to pass through on my modem and it changed to type 2 more info email me at joshuaboo@aol.com on add me i believe my ps3 thing is ADV_WARfighter
Jun 10, 2009 | Netopia (3347NWG-VGX) Wireless Router...
WHAT ARE THE STEPS TO HOOKING UP MY WIRELESS ROUTER TO MY NETOPIA ROUTER - RIGHT NOW NETOPIA IS BEING FED BY MY CABLE MODEM
the cable modem should be giving the netopia an ip address
go inside the netopia by opening Internet Explorer and type 192.168.1.254
a little window will pop open
the username is admin, the password is the serial number on the bottom of the netopia
once in, click on configure, lan, then wireless at the bottom
make sure the wireless box is checked
name your network (SSID its called) like randy578
then click advanced if you want to enable wireless security encryption, your key to get online securely
click submit underneath it
clike the yellow triangle up at the top right
click save and restart
in like 2-3 minutes, click the wireless connection icon by your clock
connect to randy578 network
you should now be online
spin
Jan 11, 2009 | Netopia Cayman 3347W-Ent Wireless Router
Programming Netopia 3347 wireless router
You mean what program? Telnet. Here's the quick setup. If it's already been installed and password protected, you'll need to grab the installation guide somewhere else.
http://www.netopia.com/support/hardware/manuals/3347W-ENT_qsg.pdf
Carl
Aug 29, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
No wireless
first make sure wireless enabled and find out what channel the item your trying to connect to is the same as the router and set both accordingly. I had same problems with security cameras i turned security settings off for wireless and switched everything to channel 6 on router and cam and wet with 806 and works fine had to restart router not reset.
Aug 07, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Wlan key for netopia 2247NWG-VGX WIRELESS ROUTER
Hi there!
I believe the WLAN key can be found at your router's set-up page or web ui. Do you know how to access it? If Not, then try to access this link and hopefully this will help you to find it..
http://www.netopia.com/support/hardware/technotes/NQG_112.html
May 04, 2008 | Netopia 2247NWG-VGx Wireless Router...
How can i unlock my router?
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, etc) and type 192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as enabling closed mode, change security protocol, password, etc.
Feb 13, 2008 | Netopia 2247NWG-VGx Wireless Router...
Netopia (3347NWG-ENT) Router (3347NWGENT) Logo
1,058 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
