Question about Optoma Televison & Video
Optoma panoview projector screen won't roll up. Model DE-GWII9106E. It rolled down but now wont roll up. I can hear the relay activated by the remote but no action.
  • gosssh Feb 22, 2009
    I have unplugged and re-plugged in the screen but it does not roll up. There is nothing obstructing or touching the screen.
  • 265 Answers
One of the springs would have twisted inside the coggs, just take it apart if you can and reallign them
Hope this helps
Posted on Feb 22, 2009
  • Optoma Master
  • 19,396 Answers
Check that the gears, and the screen itself is not stuck with dirt, that can be reason for screen not rolling up.
    Brigadier General:
  • 8,619 Answers
Hi
Please try to switch it off and then switch it on . Also check for any obstructions on the motor/screen.
  • Rylee Smith
    Rylee Smith Feb 23, 2009
    As there springs from the sides can get dettached while pulling it too hard or may have deformed. Please check for any detached or deformed springs.
    Also check for any obstruction near the motor assembly
    Thanks
    Rylee
Just purchased a refurbished optima ep716 projector won't synch-keeps rolling through search mode - I have it connected using the SCART setting.
Reduce the screen resolution of your computer monitor to 800 x 600 and check. Let us know the result.
Optoma is a SVGA projector. i.e. the maximum resolution supported by your projector is 800 x 600.
Sep 26, 2011 | Optoma EP716 Multimedia Projector
My mig welder will no longer push the wire through. I have removed the wire but the drive wheel will not even turn. When I pull the trigger I can hear the load click as it normally does but nothing...
If you presure off the drive rolls so that there is no wire between them and that there is space between each of the rolls and the rolls still do not turn and you hear the drive roll relay activate then I would say that the drive roll motor might of burned up, which is not uncommen for a mig welder. almost any dealer can get a replacement motor for the make and model of the welder you have or at least a dealer for that brand will get it for you. Hope this Helps Don
Dec 17, 2009 | Computers & Internet
Hi! where can i purchase a 12 volt trigger cable for a motorized screen
Most projectors have a 1/8 inch (mono) or tip and sleeve female connector for screen trigger and output 12volts dc when the projector is powered up. So if the Optima screen has the optional trig in and it's 12 volts the cable is very easy to put together. Optima may have a cable available or you could spend just a few bucks at Radio Shack and your all set.
Oct 31, 2009 | Optoma Panoview Matte White Motorized...
When unit powers up - nothing shows - menu rolls
resit your projector to factory default. if problem occur clean the entire projector. or change your projection bulb.
Oct 07, 2009 | Christie LX45 Multimedia Projector
Where Can I Buy the Power Adapter ?
follow this link-
http://catalog.ebay.com/Optoma-PanoView-PV755A-White-15-inch-LCD-Monitor-/52116071?_tab=2
hope it helps-
Aug 14, 2009 | Optoma PanoView PV755A 15" Flat Panel LCD...
Optoma HD65: no power after replacing lamp
i was blowin air in the back vent and i heard popin sounds and now i have no power
Apr 24, 2009 | Optoma HD65 DLP Projector
My optoma ep716 is unable to communicate with my laptop
Hi there
Right click on your desktop and go to properties , then go to settings and check if your resolution matches that of your Projector's i.e. - 800x600 for SVGA or 1024x768 for XGA
Also check in the advanced settings if your secondary screen is activated.
Then hold down the Fn ( Function button - located just left of you space bar at the bottom row of buttons ) and press in your F-row buttons the one with a screen or two screens - at the same time.
This pushes the siganl to the Projector if it doesn't pick it up automatically.
Apr 17, 2008 | Optoma EP716 Multimedia Projector
Televison & Video Logo
157 people viewed this question
Top Optoma Televison & Video Experts
jasbo
jasbo
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
