Question about Whirlpool Washing Machines
Cycle wil not start- E00 showing on screen
Washing machine type: AWZ 514d 1400 cycle and integrated
After pressing start button, cycle time will reduce by one minute then s strange noise comes from machine and after another two minutes or so noise stops and E00 shows up on screen.
SOURCE: Washing machine stops when there is 19 minutes left!
Had the exact same problem. Washer would wash fine, but would drain very slow, not spin and then the cycle would pause and not restart. Read this chain and fixed the problem while at home for lunch. Take the front access panel off by the screws underneath the panel. There is a white cap facing you. Unscrew slowly with a bucket underneath to catch the water that did not drain. Once it comes completely out, you'll see all the junk in the filter. My problem was washing my dogs kennel blanket. She is shedding really bad and the filter was full of dog hair. Cleaned the filter, screwed it back in and it ran perfectly. Saved a $75 service call from GE. This is something that should be in the owner's manual.
Posted on Apr 17, 2008
  • 53 Answers
SOURCE: Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Posted on Nov 01, 2009
Testimonial: "Thank you so much - exactly right"
  • 744 Answers
SOURCE: In the Spin cycle, after 9 minuts, it will stop with a "UL".
"UL" means "Unbalanced Load" - make sure the washer isn't overloaded first or if you are doing rugs, blankets, or lots of jeans, split the load. You can also try running an empty or light load and see how the machine behaves.
If you still have the problem, you may have some issues with the drum bumpers, etc., but try the easy things first.
Posted on Jul 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Ariston delay timer problem AVXL129 washing machine
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
  • 500 Answers
SOURCE: Bosch exxcell 7 washing machine
Hi hulley3,
Keep the Start Button Pressed in for 5 sec.
If it does not help, try keeping the Power button in for 5 sec.
Should reset Child Lock.
Regards :-)
* If you found this solution helpful, please rate it
Posted on Jul 08, 2011
Hi my Electrolux EWF1074 isn't working. The timer is counting down but there is no water in the machine. I tried resetting it but it didn't work. Could someone please help me. Regards Matt.
Rapid reading of alarms:
Press the START/PAUSE button and the nearest option button (4) simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
ewf1074-2rgnvy5j4oifscmshudmmeh4-3-0.jpg After reading error code (look display) will be a lot clearer in which phase of the washing cycle has occurred or is happening malfunction.
New washing machine (electronic) compared to the old models (electromechanical) consume much less water, so it looks that your washing machine is working properly, otherwise it would be stopped. This will be confirmed if the display show E00 which means there is no any malfunction. Any other error code, for exp. E10,E20,E30, E40, E50...... means some malfunction.
Dado
Mar 11, 2017 | Electrolux Washing Machines
I have a Zanussi Jetsystem 1400 7kg washing machine it keeps coming up with a lock on the error screen and won't start for me
have you checked to see if child lock is enabled? does the door lock when start button is pressed?
Apr 10, 2014 | Washing Machines
Electrolux 8kg won't run
This is probably normal operation , you can press the start/pause and cancel button at the same time to see if you have a error , if you get E00 this means no error if you get a E21 (example) then look and see what that error is
Feb 20, 2013 | Electrolux Washing Machines
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 20, 2012 | Bosch Washing Machines
Got an error message E43 model WPRB9220D0WW
E43 is for "excessive drive system brake time"
Reset with
1) unplug 3 seconds,
2) hold Power & Start to display "Jr",
3) cycle thru using the Custom 2 button (3 times) to display E43,
4) hold Power & Start to clear code to E00,
5) stop.
Jun 29, 2011 | GE Washing Machines
Bosch classic 6 1400 express washing machine - key lock symbol illuminated on panel when machine turned on so machine will not start. No instruction manual so wondering how to turn the lock off? Many...
This is symbol shows that the child lock has been activated. This can only be turned on/off at the beginning or end of washing programme. To activate/de-activate this, just press and hold the Start/Pause button in for 5 seconds. The time settings will then re-appear and then you can proceed as normal
Oct 17, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Annoying beep when wash cycle finishes on bosch classixx 1400 express
Starting with the rotary switch in the off position, turn it one click clockwise, press and hold on the bottom right hand button, turn the rotary switch one more click CW and release the button. The number displayed is the volume for button presses, press the centre right hand button to increase/turn off (0). Turn the rotary switch one more click CW to select end of cycle volume, agjust and set the rotary switch to off to leave set up mode.
Dec 06, 2008 | Washing Machines
My hoover washing machine 1400 spin 8kg hd vision hd
Hi On my washer when I press the start button when allready in opperation all the lkights flash and it stops as this second press of the button pauses the machine and need the start button to be pressed again to restart the machine
Hope that is cleas and helps
Angela
Jun 22, 2008 | Hoover H130E Front Load Washer
HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Feb 04, 2008 | Hotpoint Washing Machines
LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Jan 06, 2008 | LG WD-16115FD Front Load Washer
Washing Machines Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
