I'm trying to get my headphones to work on my mac mini for Skype. The headphones and mike plug into the Bose sound volume controller. I've diligently selected the appropriate device for input and output on the mac sound preferences, and Skype preferences. I've made sure that mute is not selected anywhere. I can hear sound through the headphones but the system is not picking up any input from the microphone. In sound preferences the sound bar does not register at all when I speak.
  • victorlunnro Feb 22, 2009
    I did as suggested. I disconnected my speaker system and plugged in my headphones directly into the back of the mac. Two jacks, one for the mike and one for the sound. Same thing happened. I could hear the sound but the mike didnt register. I swapped the plugs around. No difference
    Sergeant:
  • 326 Answers
As you mic settings are not selected properly you will have recofigure your mic settings.to make it work.check out the current settings.something may be disabled what should be actually enabled. and was it working before on micro phone.tell me that.
Posted on Feb 22, 2009
  • 13,433 Answers
Double check the mic settings, does the mic work? Try line in instead of microphone.
  • 265 Answers
If you try plugging them into the audio in on the mac this will work.
The reason the mic is not registering is because the Audio In on the speakers are to attach an Ipod ETC to play through your speakers so it will not go through to the mac as you only have an Audio Out connection to the speakers and not an Audio In from the speakers to the Mac.
So please connect them to the Pink Audio In connector on your mac.
Hope This Helps
Skype worked last time I used it but now, no sound on either end, what can I do?
Check if your microphone and headset is plugged in correctly and try again.
Go to Settings >Sound >Input and check if your microphone is selected.
Go to Settings >Sound >Output and check if your headphones are selected.
Jan 29, 2016 | Apple iMac G4 Desktop
I am trying to connect my Bose Wave Radio to my Yamaha RX S 70 receiver so that I can listen to the radio through my speakers. Right now the speakers are connected to the Yamaha...but radio isn't playing...
There's actually 2 ways of doing this.
Using the variable out connections on the Bose, connect your L&R channels to the desired input, I recommend the auxillary, on your Yamaha and select that input. Turn the volume all the way down on your Yamaha. Turn the volume on your Bose all the way up; then readjust the volume as desired on your Yamaha.
Optional connection; the headphone jack. Connect a 3.5mm mini to stereo plug cable from the Bose to Yamaha in the manner described as above and use the volume control approximately the same way.
Dec 12, 2014 | Yamaha Audio Players & Recorders
Why can my friends not hear me talking to them on Skype?
On a Mac mini made in 2010 or later, you'll need to use an external microphone to communicate as they're not built in. Plugging in a pair of Apple EarPods or headphones into the headphone jack should work just fine.
USB microphones will also do the trick (but you'll need to adjust some audio settings in Skype).
Hope this helps!
Sep 13, 2014 | Apple Mac mini Desktop Computer (Aluminum...
I cannot seem to hook up my mike and ear phones. I need help
Your headphone has two wires connecting to the head-speaker. look at where you will plug the headphone to your laptop. u will see two holes. first for audio(green code) the second for mic(other colour). make sure the same logo matches. this will work automatically. just increase the volume of the laptop.
Sep 13, 2011 | Skype IM
The nexxtech hd portal 720p installation disk comes up on my mac desktop but when i click on it, it goes in to a file and i can't seem to instal anything everything either has no default application...
I have the same unit and it works fine on my Mac Mini. All the stuff on the disk is for PCs, not Macs. You don't need to install any drivers for this webcam when using it with a Mac. Just plug it in and it will work. If you are using it on Skype, for example, you have to select "preferences" / "sound" and then change the "input" to USB. That will make the microphone work. You can adjust the mic input volume in your Mac "System Preferences" / "Sound." This is one of the few cameras out there with a mic that works through the USB, so don't give up on it too easily!
I get a very slow frame rate with this camera, but I've had the same problem with every other webcam I've plugged in!! Otherwise the quality is fine. If anyone knows why my frame rate is so slow, I would appreciate your ideas!
Jul 09, 2011 | Computers & Internet
My microphone on Dell Latitude D505 does not speak out eg. on skype? Can u assist Thanks
We need to determine if your mike works at all. Lets start by launching Sound Recorder from START --> PROGRAMS -->ACCESSORIES --> ENTERTAINMENT --> SOUND RECORDER. With that application going, click the record button and talk. See if you can record anything and then play it back. If it works, the issue is something with Skype, if you get no sound, you've got either a problem with the mike itself (not likely) or a Windows driver problem or ...
...easiest fix, is that the mike is turned off in the volume control. Go to START --> PROGRAMS -->ACCESSORIES --> ENTERTAINMENT --> VOLUME CONTROL. When it comes up, click on OPTIONS --> PROPERTIES. You should see an option of displaying playback (default) or recording volume. Select recording. You can now confirm that there is a check mark next to digital mike which turns it on.
Hope this helps!
Jun 20, 2011 | Dell Latitude D505 Notebook
Control Pod for Bose Companion 5 speaker system
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
Jan 29, 2009 | Bose Companion 3 Computer Speakers
I have video but no sound using SKYPE.
It sounds like you're asking whether headphones are necessary to the Skype experience.
You don't absolutely *need* headphones (or a microphone or a headset that has both), but if you don't use headphones, then your Mac external microphone might pick up the sound of your conversation and you might get unpleasant levels of feedback.
If this doesn't answer your question, please write back with the following information:
1. Your Skype version (click Skype --> About Skype)
2. Your model of Mac
3. Whether you are having problems with your audio
- On Skype only?
- On other applications?
- In general?
4. Whether you have tried clicking on "Skype Test Call"
- Whether you could hear the voice giving you instructions
Thanks!
Jan 23, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Headphones
Please ask someone else.
To get the best support you could go get the premium assistance.
Or you can keep asking around, I don't know how to solve your problem.
Please leave this as unrated / not rated. Please don't rate the solution.
Thanks.
May 19, 2008 | Bose QuietComfort 2 Consumer Headphones
IMick on Mac Mini
Yes, it does work for the mini (I have the same). Drivers seem to be built into the system, so you don't need to download anything with OS X 3.9 or later. Make sure your switch on iMic is switched AWAY from the mike input plug, and you may try plugging your iMic directly into your MacMini (or through a powered 2.0 hub).
Good luck.
Mar 09, 2008 | Apple Griffin iMic External Sound System
16 people viewed this question
 Grubhead
Grubhead
