Cannot use VOIP because Bigpond Australia has blocked port 5060 is there anyway to unblock this port? I have a 2701HGV-W modem Thanks for any help Andrea
  • Anonymous May 04, 2009
    I can access thr modem page and can't see to configure voip setting
See this link, and guide from "Minisubwoofer", posted 2007-Oct-1, 1:53 pm , it worked for me with Exetel: http://forums.whirlpool.net.au/forum-replies.cfm?t=808533
Posted on Jun 03, 2010
I can not get port to let me get in coming calls
Most likely your system has a firewall somewhere .
Could be the router. You need to log into the router and check TCP ports 5060 and 5061 are allowed in the firewall settings . ring your isp and ask them to help you get Voip incoming ports to work on your router for incoming Voip and tell them the device you are trying to use
Jan 01, 2015 | magicJack Plus
How can i use the wi fi from 2Wire 2701HGV-W modem - ADSL - BigPond
the wifi information is inthe bottom of mdoem
ssid :
and
wep :
you need that info to conenct
May 04, 2010 | 2wire (1000-000057-000) Modem
I have a bigpond supplied 2wire wireless internet modem (2701HGV-W) which works seemlessly with my laptop running XP-sp2 for internet and email. Recently I purchased a Brother MFC 6890-CDW which offers...
Check if it's recognised on the local area network etc,make sure driver is installed and you may need to reset all pc,router etc to get connection.Now remember you need a router for this to work,with only a modem it will not function.You also need to restart all instruments etc before it's picked up by the router and the network..Google a bit and it will solve this.Make sure it uses wifi and not bluetooth as then it will need the right bluetooth connection to your pc..
Jul 27, 2009 | 2wire (1000-000057-000) Modem
Portforwarding on Linksys WAG200G wireless modem/router
Bind the IP address to that port UDP or TCP (or both..your preference) #5060 in the forwarding section of your router. check the box to enable it. Click APPLY or OK or NEXT...wait for changes.
Mar 10, 2009 | Linksys WAG200G Router
How to monitor all traffic from PCs on ADSL wifi 2701hgv-w modem
to monitor all traffic from all computers your computer would have to run the internet connection(modem) and you would have to connect your router to that. that way all traffic would pass through your monitoring computer with watever software you use to do this. Pritty sure this is the case.
Feb 25, 2009 | 2wire (1000-000057-000) Modem
Linksys SPA2102 interfearing with winmx/360 sharepro, frequently resetting connection
If your planning to connect the phone adapter behind a router make sure that the following ports are open/forwarded on the router; UDP ports 5060-5061, UDP ports 16384-32767 take note that 5060 and 5051 one are SIP ports and must be assigned to the IP address of that was assigned to by the router to the adapter or the IP that was manually configured on it.
I found a link that could help you check the setting on your linksys phone adapter
http://www.voipvoip.com/linksys-pap2/
Hope this will help you solve your VOiP problem...
Regards,
Sep 11, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
What port to open
Vonage uses these ports: 5060 - 5070
10000 - 25000
Jul 23, 2008 | Linksys Wireless-G WRT54G Router
Siemens S765IP w/ router linksys wrt150n
What VoIP provider are you using?
Try connecting router directly to the modem and the laptop to the router and see if your laptop can get out onto the internet. If you cannot, then your router might not be handing out IPs to the devices on the internal network. You can enable the DHCP server on the router using the administrative web interface at http://192.168.1.1.
If you can get out onto the internet with your laptop behind your router then look at defining a DHCP reservation on your router for your VoIP phone and then forwarding the following to your phone:
5061 UDP
5060 UDP
10000-20000 UDP
These are common ports amonst the VoIP providers.
Hope this works, if not we'll give it another shot.
Jan 30, 2008 | Linksys Wireless-N WRT150N Router
Computers & Internet Logo
954 people viewed this question
David Payne
David Payne
