Question about Whirlpool GB2SHDXP Bottom Freezer Refrigerator
Whirpool fridge is warm, freezer is working
I have a whirlpool bottom mount fridge - about 4 yrs old. Freezer works fine but fridge is warm. Removed all items and air from freezer doesn't seem to be reaching the fridge. Temp does not change when changing therm. Fan is working. Can we fix this?
  • leacock Feb 23, 2009
    After trying to figure out things ourselves, my husband and I asked my handyman brother to come by and I told him your diagnosis and viola! Built up frost in the freezer. Thx!
  • Whirlpool Master
  • 3,361 Answers
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Posted on Feb 22, 2009
  • steve
    steve Feb 23, 2009
    Good. Now you know what you have to deal with.
    Defrost thermostat.
    Defrost heater and defrost timer.
    Glad I could help.
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
My whirpool fridge about 3 years old Whirpool model GX5FHDXVY00 the fridge is getting warm all the time, call up a tech and he has no idea what's wrong. I have to sometime manually defrost, unplug so...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Aug 14, 2011 | Whirlpool GX5FHDXVY Stainless Steel (248...
Fridge and freezer works fine-not iced up but
Ya, if compressor is working cond. fan also works. Reduce thermostat sett.
Nov 10, 2009 | Amana ABB1927DE Bottom Freezer...
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 | LG LFD25860
Fridge not cold, freezer on bottom works fine
you have defrost problem 1 timer defrostthermostart or heater
Jan 19, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
My amana bottom freezer won't cool both the fridge and freezer are warm
I just had the same problem with the same fridge. When I removed the inside panel in the freezer, I found that the cooling/circulation fan had fallen due to the mounting screws having rusted off. I removed the fan housing to get the screw ends out from the back side and remounted the fan with new screws. The fridge and freezer both work fine now and I'm assuming it will for many more years until it happens again.
Nov 04, 2008 | Amana ABB1927DE Bottom Freezer...
Freezer ok(Whirpool -6 yrs old), but the fridge is not cooling sufficiently, only around 50 degrees. A lot of frost build up in the freezer. Have to thaw it every couple of days.
defrost system not working. take back panel off inside freezer.
check continuity thro the defrost element and stats mounted on the pipework
if all ok then points to a fault with timer or module
Sep 09, 2008 | Refrigerators
Whirlpool fridge
3 things can cause this:
1) Inoperable fan in the freezer.
2) Defrost problem (frost build up on back panel in the freezer)
3) Damper inoperable (vent in the fridge section)
Look for these symptoms and let me know what you find.
Nov 17, 2007 | Refrigerators
Bottom mount freezer not getting cold enough
You have a failed component or components in your automatic defrost system. This is why you have excessive frost inside the freezer along the back wall. The timer could be stuck in run mode. The defrost thermostat (bi-metal) could be defective or the defrost heater could be open or shorted.
Sep 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool GB2SHDXP Bottom Freezer Refrigerator Logo
1,316 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
