Question about Microsoft Windows XP Home Edition
Horizantal split screen
I was opening a new program at the start menu and the screen divided horizantally-top at the bottom and vice versa. I have tried everything
  • Anonymous Apr 12, 2009
    The solution offered doesn't work for me, nor does an attempt to drag the toolbar. There is no problem with 800 x 600 defintion; it is only at the 1024 x 768 setting (which we have used for years without a problem.
  • 27 Answers
Ok click on your start botton when it opens click on a white part that in that start section but not on a program just some blank space in there so right click that area and click on properties then click on which view you would like. should fix it for you. please rate me thanks
Posted on Feb 27, 2009
Where to find the chrome menu icon
Find the icon with horizantal lines at top right corner of chrome
Oct 20, 2014 | Google Chrome
Xl 2400 replacement bulb---dim after replacement
did you use a genuine sony replacement bulb or aftermarket? Often the aftermarket lamps are not up to par with the OEM versions.
Nov 01, 2012 | Televison & Video
Black thick line going horizantal on screen can it be fixed?
Usually a bad board but someone has to open set and troubleshoot to decide which board is the problem.
Apr 08, 2012 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
Hello, my hpw2007 screen has horizantal bands that cycle from the bottom to the top in a loop. The screen is older, and has been dropped lightly twice. Can it be fixed or these effects be eased somehow.
Yes, FIRST thing is REFRESH RATE in display driver advanced settings, SECOND one is incorrect driver using, check the drivers Graphic card (Display Adapter) and Monitor And last one is a BROKEN WIRE in monitor data cable. Good Luck.
Sep 14, 2011 | Computers & Internet
I haveMy compaq presario CQ40 and my monitor screen got flicker always for past few days and more red horizantal lines @bottom of the screen, where i couldn't see the data,time,date... Plz help me...
This is usually a sign of either a bad LCD screen cable, a bad LCD screen, or a bad display adapter.
If you connect an external monitor & you get a picture without these red horizontal lines, then your display adapter is OK.
Diagnosing a bad LCD screen cable or a bad LCD screen requires that you disassemble the LCD screen panel, & swap them one at a time with a matching part. This way you can identify which part is causing the problem & replace it.
Sep 02, 2011 | Compaq Presario CQ40 Series Laptop Charger...
Darker screen on the right hand side of my Sharp
try going to menu and center the screen both vertically and horizantal, the manual should help
Feb 25, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The blackberry bold trackball will not work when scrolling down
  • Go to main menu
  • Go to Options.
  • Select the Screen and key board.
  • Scroll down and Select Horizantal and Vertical sensitivity to 100.
    I hope you can fix this issue by doing this
Oct 18, 2009 | RIM BlackBerry Pearl 8100
How do I remove the rear door panel from my 2000 toyota camery? Specifically the inside door handle cover. I have the panel 90% off, however, I believe the door handle that releases the latch seems to be...
It is fragile but you take a small screw driver and pry the top horizantal part and then the bottom horizantal part slightly away and wella it will come off. The handle actually stays on the door I think. The cover comes off. When you do it once you'll see how easy it is.
Jul 16, 2009 | 2000 Toyota Camry
Sony kv32v15, Red screen with fine horizantal lines then shuts off
I would suggest to measure the 200 volt B+ at the CRT socket. If that voltage is found to be low, disconnect the socket from the CRT and measure again. If the voltage reading returns to normal you may have a defective CTR.
Also check for open or defective diode on flyback transformer for the 200 vdc source.
I would also suggest to take all the necessary precautions since you are working in a very high voltage area.
Good Luck.
Jan 14, 2008 | Sony KV-27XBR45 27" TV
Microsoft Windows XP Home Edition Logo
90 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
