Question about Frigidaire ATF6000ES Front Load Washer
The metal wheel that the belt goes on is cracked
The metal wheel that the belt goes on by the tub on a frigidaire gltf1670as0 front has a cracked spoke. Can I replace just that wheel/pulley?
Thanks
  • 188 Answers
Yes the drive pulley is replaceable. Here is the part number... 131883400
Posted on Feb 23, 2009
  • Frigidaire Master
  • 3,361 Answers
Yes, it is replaceable.
Posted on Feb 22, 2009
2 Suggested Answers
  • 50 Answers
SOURCE: The metal wheel that the belt goes on by the tub
Yes.
Posted on Feb 26, 2009
GLTF1670AS0 front load washer
What is your concern or questions with this particular washer?
Dec 27, 2012 | Frigidaire GLTF2940ES Front Load Washer
I have a frigidaire front loader that when it goes into high spin it kicks out. i have replaced the moter, door switch, same issue
Sounds like the unit is not balanced, the tub that is, or the belt and pulley system is going out on you. Contact a professional to take it apart .
Aug 11, 2012 | Frigidaire ATF6000ES Front Load Washer
Squeeky dryer
if the squeeks are coming from the tub while turning. it may be the front tub glides. but the dryer will need to come a part to fix them. good-day ! more possible symtoms-- Damaged Drum Wheels, Deteriorating Drum Bearing, Failing Idler Pulley Wheel, Loose Belt.
Mar 08, 2012 | Frigidaire Dryers
The drum seems loose and is make a metal on metal sound when turned on.
your problem is the rear support bearing [part#5303281153 / about $30.00]
unplug the dryer / lift the top (there is a spring tension clip about 3-4 inches under the front of the top / use a flat blade {like a putty knife] to press in the clips / remove the front [a phillips screw coming in to the front from inside the dryer cabinet, on the left and right side / disconnect the wires to the door switch / front will tilt towards you and slide off two bottom clips / disconnect belt by reaching behind blower housing and pulling the belt off the pulley / remove drum / part of support bearing it attached to the tub, and the other part is attached to the dryer cabinet [if you get a FrigidAire factory part, it will have instructions]
Jan 18, 2011 | Frigidaire FDE336RE Dryer
Tub cracked on my Fridgidaire front loading washing machine
sorry no recalls on fridgidaire front load,,there pretty good units,,the mildew and slugg comes from not using he or low suddsing detergent..now dont move so fast ,,because a new spin basket may not solve your problems with noise..check that back tub bearing while you have it a part..now that unit is fresh and new ,,clean the unit every other month with bleach..hot wash cold rinse,,that will keep suds slug and smell out unit...onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Washing Machine Model # GLTF1670AS0
back bearings defective,,,should sound like train coming down on track..
Dec 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Plastic Mountings Let Loose - Hole in back of washer
you can fix it buthte cost would outwieghthe cost of new machine,all front loaders not exclusulve frigidaire have simillar issues, if no the tub cracking the rear bearing goes bad
Dec 03, 2008 | Washing Machines
Frigidaire front load washer won't spin, belt looks good, makes noise
Don't have much experience on Frigidaire. Is the motor a brush type, capacitor type or one of those new DC types? If it's got brushes and they are ok, then I would say your armature is up the creek. If it's a capacitor type (unlikely) then the capacitor is most likely duff. If it's the new DC type it could be a lot of things, most likely the module which breaksdown and passes an AC component in the motor supply which make the motor tremble but not rotate
Nov 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire gltf1670as0 Front Loading Washer
door lock position switch may not have been properly tightened at factory. first position then tighten the switch
May 11, 2007 | Frigidaire GLWS1233A Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
89 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
