Question about Frigidaire ATF6000ES Front Load Washer
The metal wheel that the belt goes on by the tub on a frigidaire gltf1670as0 front has a cracked spoke. Can I replace just that wheel/pulley? Thanks
  • 50 Answers
Yes.
Posted on Feb 26, 2009
I have a frigidaire front loader that when it goes into high spin it kicks out. i have replaced the moter, door switch, same issue
Sounds like the unit is not balanced, the tub that is, or the belt and pulley system is going out on you. Contact a professional to take it apart .
Aug 11, 2012 | Frigidaire ATF6000ES Front Load Washer
Squeeky dryer
if the squeeks are coming from the tub while turning. it may be the front tub glides. but the dryer will need to come a part to fix them. good-day ! more possible symtoms-- Damaged Drum Wheels, Deteriorating Drum Bearing, Failing Idler Pulley Wheel, Loose Belt.
Mar 08, 2012 | Frigidaire Dryers
I have a Frigidaire GLTF1670A washer. When the washer goes into the spin cycle, I have noticed a progressively louder belt slipping sound. The washer is 7 years old. Do I need to replace the belt, or is...
Disconnect the washer from the electrical supply then remove the screws shown holding the rear access panel to the washer’s rear panel and lift the access panel off.
Cushion the bottom of the cabinet opening as shown to avoid hurting yourself with the sharp edge.
Plug the washer in then start a loaded spin cycle to check for belt slippage and the motor operation itself.
Replace the belt if loose or slipping. Remove the belt by turning the tub drive pulley and rolling the belt off the pulley.
Install the new belt in reverse order by wrapping it around the motor pulley and on one side of the tub drive pulley then turn the pulley to the other side in such a way that the belt wraps completely around the pulley. Secure the rear access panel back into position to complete the procedure.
Note: This advice is intended solely for the asker dolanbox as per live chat discussion.
Aug 30, 2010 | Frigidaire GLTF1670A Front Load Washer
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Please check this diagram for the part number F28(drive belt)--
Please post back for any further assistance.
Thanks
Daniel
Jul 24, 2010 | Frigidaire FWS833A Top Load Washer
The belt keeps coming off and does not sit straight on the wheel
If the belt keeps coming off, then it could be worn or stretched belt, loose drum pulley, a cracked spoke on the pulley, or the main drum bearings have failed, thus allowing the drum to run off center.
Hope this helps.
Feb 01, 2010 | Indesit Washing Machines
Replacing a belt on a frigidaire glft1670a
First remove the top of the unit by taking out the 4 screws at the back of the machine. After the screws are removed, push the top foreward and lift it off. Next, remove all of the screws on the back of the machine and remove the rear cover. The belt should be infront of you now. If your belt is broken or worn, go buy a new one. Put the belt in the grooves of the motor pulley first. Hold the belt onto the pulley while you use the other hand to start the belt onto the wash tub pulley. Slowly rotate the large tub pully and feed the belt on fron the motor pulley. There will be a fair amount of pressure and this is normal. Keep turning the large pulley until the belt slips on fully. Spin the large pulley a few rotations to make sure the belt is centred and is in the proper grooves of the motor pulley. Now replace the back cover and top in the reverse order.
Feb 10, 2009 | Frigidaire GLTF1670A Front Load Washer
Noisy water pump pulley,alternator pulley..timing belt tensioner
I have a 1995 xj6....same problem. I replaced the belts, water pump, and the alternator. Still does it. As I play with the tension on the belt (belt that drives water pump, alternator) it goes away and comes back. If I remove the belt, the metal to metal screech stops. I then, with just the belt, turned the main pulley on the front of the engine, and there was the sound! The main pulley has 2 belts that run on it. Also, 2 pulley tracks. They SHOULD move simultaneously and be super meshed. But the rear one moves on its own under tension until it warms up and I guess, the bushing maybe expands. Now.....how do I fix it??????
Nov 19, 2008 | 1995 Jaguar XJ-R
How to change drive belt on ATF7000ES
disconnect the unit from power, and water...
move away from wall
easiest access is from underneath, by tipping it back around 45 degrees. I don't recommend placing it on it's back, for a variety of reasons
you should see the belt right there. you'llneed to loosen the clamp holding the pulley wheel that belt goes around, and then it should slip off nicely..
make sure to tension the pulley again snug, but not too tight..there's a torque spec for it, but it's tough to get a torque wrench in that small of a space
hope that help you and thanks for using Fixya
Mar 02, 2008 | Frigidaire ATF6000ES Front Load Washer
How much play in rear pulley
Scott, the pulley should be tight, no play, Check to see if one of spokes are cracked on the pulley. I do believe that you have a 5 year warranty on the bearings on this machine, parts only. It's a huge job to replace the bearings on this model. Give Sears a call to see if they will cover the parts. You will need the rear tub and bearing kit...Good luck
Jun 21, 2006 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
107 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
