Question about Dimplex Heating & Cooling
On the DS2205 the electric plug looks like it was starting to melt. Also can I get manual for it?
    New Friend:
  • 92 Answers
Do not replace plug if you are melting plug then you are putting a band aid where you need stiches,you have a over heating problem with that heater or outlet which could lead to a fire call a pro or stop using heater
Posted on Feb 23, 2009
My dryer will not turn on, there is current to electric plug.
The thermal fuse is located on the back side of the dryer. If you see lint built up that fuse can be melted. If it is melted then the motor won't run because that fuse is in the same circuit as the door switch. So if the fuse is good look for a bad door switch.
Roper dryer tuneup
Service manual and more
Sep 11, 2011 | Roper REX5635E Dryer
Wascomat TD75 gas dryer is not starting, just blow the fuse on the board inmediately
HI- If it is electric (220V) you may have a bad plug or outlet that is shorting the circuit breaker. Usually when there is a short in the unit it does not blow the breaker. Leave the breaker off and take the plug out and have a look for any burt or melted parts. If that looks ok then have a Tech look at the dryer, something is shorting or going to Ground and putting enough load to trip the fuse. Wouldn't keep trying to start it. I know, not much info but someone really need to be there to look at it in person. Best regards.
Sep 24, 2010 | Dryers
Kenmore drop-in electric range plug melted
Hello- Yes it can be fixed- first, make sure outlet is not damaged. If it is, it will need to be replaced. Next, plug is wired into a terminal block on back of unit. With care, this cord is easy to replace. And safer than it was before. A loose plug, or wire caused the fireworks. Let me know if this info helps- have more if needed. -Thanks- ED
Mar 03, 2010 | Kenmore 45062 / 45069 Electric Kitchen...
Problem with the electrical plug on LG Washer
some times the cords when produced are defective from start, replace it or cut it back to where wire is good, and put a new end on it, then have the running current checked on the unit when in full operation and make sure units not overdrawing and ruining the cord
Oct 26, 2009 | LG WM2277H Front Load Washer
Fuses no. 7 & 37 on my 318is K-reg Bmw keep MELTING.
you have to figure out where there is a short in your wiring--follow wires, look for broken, missing insulation--if it started in lights, look there first maybe. Also check the connections of plugs. Good luck it may take some searching.
Mar 27, 2009 | 1996 BMW 318
G.E. electric dryer terminal block and wires are burnt. I took the dryer apart to clean the inside of dust and lint. I put it back together and plugged it in. The breaker tripped,and I looked at the...
you did not say how old? but I find that all it takes is one wire to get old, and starts to heat up because electric cant flow through it, then it gets worse and worse fast, then heats up the whole block, till the whole thing gets melted...bad thing is its happens slow enough that the standard 30 amp breaker won't trip during this slow melt down!
Mar 13, 2009 | Kenmore 64902 Electric Dryer
Dryer making a buzzing sound in the console but not running
Unplug the dryer.
Remove the rear panel.
Look on the exhaust vent for a failed fuse.
It will be narrow and about 1 and 1/2 inches long.
Remove the 2 wires and jump them together.
Plug in the dryer and start it.
If everything works OK replace the thermal fuse.
Feb 27, 2009 | Roper RES7646KQ Electric Dryer
Electrical schematic
Look, usually in the back, of a good service manual. Manufacturer shop manuals, Haynes, and Chilton's usually all have wiring schematics.
Jul 06, 2008 | 1993 Chevrolet Cavalier
Melted electric brake
check out www.toolpartsdirect.com for diagram & cost. if the board are burnt. it is hard to get the board. i suggest covert the unit to CMM1200. you need convertion kit includes instruction how to install, wiring assy & charger. see webstie i mension & look for cmm1000 type 4. item 82
Jun 28, 2008 | Black & Decker 19" Electric Lawnhog...
LEQ9508PWO breaker pops
IF IT SMELLED HOT, I WOULD LOOK A THE ELECTRICAL WIRING FROM YOUR OUTLET, THROUGH THE ENTIRE DRYER. START WITH PLACES OF EASY ACCESS AND WORK YOUR WAY INWARD. LOOK FOR MELTED OR BARE WIRES THAT MAY HAVE COME INTO CONTACT WITH THE METAL FRAME OF THE DRYER.
TRY SELECTING FLUFF AIR (NO HEAT) AND SEE IF IT WILL RUN O.K. IF IT DOES, I WOULD SUSPECT THE HEAT CIRCUIT. TAKE THE BACK PANEL OFF AND INSPECT THE WIRES AROUND THE HEATER ASSEMBLY.
Apr 07, 2008 | Whirlpool LEQ9858P Electric Dryer
Heating & Cooling Logo
103 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
