Question about Sega Genesis Console
Power Problem I just bought a used sega genesis from a game store. i got it home and hooked it up but when i turn it on the red powr light doesnt do anything and nothing happens on the screen. im assuming its just broken but i wanted to know if there is anything anyone knows for a quick fix.
  • Anonymous Apr 23, 2009
    My Sega Genesis will not even turn on and the power light won't come on.
  • 60 Answers
Um take it back
Posted on Feb 23, 2009
    President:
  • 894 Answers
Well it might be the ac adapter that is causing the problem so you could try a new adapter to see if it works again if not then its a power system failure.
Posted on Jun 16, 2011
When I try to hook my Sega Genesis up to my TV, why does nothing happen?
you should have a red light and if its on it should be working. I would just go on Amazon and buy a AV connector for the system, no need to use RF like its 1989 :)
Dec 31, 2015 | Sega Genesis Console
Sega genesis wont start up
I had had a problem with my old Sega Genesis console the red light would not turn on even though I had turned the power on after a few se the voltage regulator got very hot really fast you could have a similar issue like I had for this if it is stone cold then it is dead. Try another ac adapter too see if it works if it does work then the ac adapter was bad. If there is no power light being on and it gets really hot really fast then it could be the capacitors that are causing it not to work or the voltage regulator is not working right. So you could buy a new one then.
Dec 23, 2013 | Sega Genesis Console
Sega Genesis Model 2 won't turn on
Well it sounds like that you have a bad ac adapter then so buy a new ac adapter the console is fine so just a new adapter that's all.
Apr 28, 2012 | Sega Genesis Console
How can I hook my sega genesis console to my Direct tv box?
Don't plug your Genesis into your satellite box. Plug your Sega into the back of your TV set. Get a Sega Genesis composite video cable. Run that cable from the mini-DIN connector on the back of your Sega to the RCA (yellow, red white) connectors on the back of your TV set. If you don't have any spare RCA connectors on your TV set, try a composite video switch.
Aug 20, 2011 | Sega Genesis Console
My sega is turning on but the picture looks snowy how do I fix it?
Well instead of using an rf switch use the av cables for sega genesis console lukue games I use the av cables instead of the rf switch easier to hook up as well.
Nov 15, 2010 | Sega Genesis Console
I recently plugged in my Sega Genesis (MK-1601) console and purchased A/V cords to hook to my tv. When I turn the power on (the red light goes on), I usually just get a flash across the screen and then a...
This is pretty common. The games just need a good Q-Tip cleaning, and then the weird clean pencil-eraser rubbing.
Get out a Q-Tip, and rub it inside the game, on the copper part (The part you stick down into the system.). Keep doing this with new Q-Tips if the old ones get soiled with black stuff. After the new Q-Tip comes out white, it should work.
Sometimes, that isn't enough. Use some Windex or any other rubbing alcohol, dip it onto a Q-Tip, and rub it onto the copper part. Then, use a dry Q-Tip to dry it off, and let it sit out of it's case and out of the system for about 20 minutes so that the alcohol dries.
If that doesn't work, use a pencil with a clean pink eraser at the tip. Rub it inside the game, and use a Q-Tip to get all of the eraser shavings out. This breaks the electro-static cling/friction made when the game is being read by the system.
And if none of that works, go on Amazon or Ebay or to the store Slackers and get new video and AC wires for the Genesis. Sometimes that's all it needs!
I really hope this helps!
Aug 05, 2010 | Sega Genesis Console
Need step by step directions to hook up a 16 bit Sega Genesis
There should be two plugs on the back of the sega. One for the power cord, and one for the audio/video cord. The audio/video cord is a coax cord with a little box in line. Hook your cable or antenna cable into the jack on the box and hook the end of the cable from the sega into your tv. There will be a switch on the sega or on the box somewhere that designates channel three or four, this is what channel your tv will need to be on to use the sega.
Sep 23, 2009 | Sega Genesis Console
Sega genesis
don't panic
sometimes the LED goes on the Megadrive
so try to tune it in anyway. (clean a game and put it in)
also sometimes you can get a "Dry joint" at the power port at the back of the megadrive.
this is fixed by unscrewing the megadrive and a little solder on the each of the 3 joints.
May 19, 2008 | Sega Genesis Console
Sega Genesis Console Logo
361 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
