Scanners
Problem for Scanners
Generic problem for all Scanners
Require driver for Ion Slides 2 PC ... usi...
By pate44 on Feb 22, 2009
Require driver for Ion Slides 2 PC ... using Vista 64 bit.
Same Problem
May 05, 2009
-   Same problem - it just records a blank image and the 64 bit driver doesn't install properly -   Guest
Apr 10, 2009
-   I have the same ION Slides 2 PC scanner, mine scans but over-exposes everything! over the 50+ slides I've scanned, only a few are actually useable. Very dissapointing, and there does not seem to be any way to fix this problem. -   cortezhome
Mar 22, 2009
-   My new Ion slides 2 pc refuses to do anything at all. On clicking "acquire from scanner" nothing happens. I assume that I need a 64 bit driver. On the Ion website there is a section for downloading 32 bit and 64 bit drivers, but the drivers aren't there. The Ion website seems to be very similar to the Ion scanner - nothing works. The solution would seem to be don't buy an Ion scanner whatever you do !-   mglee320
Mar 14, 2009
-   Scanner blocks after a while. -   velpeleven
Solution #1
posted on Aug 16, 2009
Somewhat Helpful)
tunbridge
Rank: Apprentice
Rating: 75%, 3 votes
My ION Slides 2 PC works fine although it does overexpose anything part of an image that is in bright sunlight.
I found that sometimes I have to click the 'acquire' button a couple of times before it 'catches' and starts that component of the application.
Was this helpful?
Yes
No
Popular Solutions for Scanners
Questions and Unsolved Problems for Scanners
Answer
I need a hendheld pen scan suitable for XP and editable on word, to save especially half of the... (More)
Answer
My SVP FS-1000 does not scan with the color or clarity of the original color slide. Yellows are... (More)
Answer
Is someone able to make a Win7 driver starting with the UMAX Astra 6400 VistaScan Utility XP driver
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Scanners:
Top Scanner Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
