Question about Sunbeam 2370 MixMaster Series Stand Mixer
I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong? Sunbeam digital meat probe thermometer has quit working after two uses. Need a replacement.
  • lmnwheels Mar 02, 2009
    I have a similar problem. I've used mine 3 times and now the temperature reading is off by approx. 30 degrees. I can't find a reset button anywhere.
    Any ideas on how to reset or who to contact? I got it as a gift so I don't even know where it was purchased.
    Problem Solver:
  • 8 Answers
I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
Posted on Oct 09, 2010
I have a sunbeam mixmaster mx9500. When i turn on, the whisk struggles to rotate at all and there is a crunching sound coming from inside. What should I do, can I repair myself? Its out of warranty.
Not knowing how handy you are I would try to take the top of the mixer apart and see what is going on. It sounds like one of your gears is either slipping or has some broken teeth. If you don't want to tackle it a small appliance repair shop should be able to fix it for you.
I just found this
Maintenance Service
Your Sunbeam Caf? Series
Planetary
Mixmaster
Power Drive should be regularly
checked. After approximately four years
of domestic use, the grease in the gear
compartment should be examined. We
suggest at that time you send the mixer to
your nearest Sunbeam Appliance Service
Centre to ensure efficient, correct servicing.
Just there recommendation but i guess a known problem.
Sep 02, 2017 | Sunbeam Food Mixers
I need to find an electrician to recondition an old sunbeam mixmaster
Look in the phone book and find a local business that repairs small appliances, call them.
Oct 15, 2016 | Sunbeam Food Mixers
Sunbeam stand mixer's mixing bowl does not turn when mixer is on!
You may have a product failure. Yesterday's Sunbeam is not today's Sunbeam.
Dec 03, 2017 | Sunbeam 2353 Stand Mixer
New mixer did not come with manual
Hi MITCH, Happy New Year! Somebody at Sunbeam must have been asleep when the mixer passed by on the production line...duh? I hate when that happens. The good news is that you can download a PDF Users Manual from the Sunbeam website. Just click on this link Heritage Series 2353 Mixmaster and look for your M-I-L’s model to about ½-way down the page. Open the file and save it to your PC.
I’m not very keen with the way Sunbeam lays out their User’s Manuals. You’ll need to do some editing and repaginating to get it into a format that your M-I-L- can use, but at least you’ll have it. You can send it to her electronically or print just the English pages and mail; your choice.
Good Luck. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Jan 18, 2010 | Sunbeam 2353 Stand Mixer
Black Residue on meat using Kitchenaid meat grinder attachment
This is a common issue with the Kitchenaid food grinder. The black residue is a product of the meat itself.
With Kitchenaid Food Grinder Attachments, it is recommended that the meat be partially frozen before grinding. This is to ensure a quality grind and to make sure the meat holds all its juices while grinding.
If any juices from the meat are leaked into the food grinder, the friction will cause a chemical reaction and turn the juice from the meat into a black substance.
Dec 17, 2008 | KitchenAid K45SS Classic Stand Mixer
Sunbeam 2346
I just did it. Get your digital camera and take pictures along the way so you'll know how to reassemble it.
On the front of the mixer, there is a chrome Sunbeam sticker. Use a pocket knife, slide it under the sticker and pry/peal it off. Then you will see a single screw that goes into the guts of the mixer. Unscrew it and remove the front of the mixer. You'll then see two screws that keep the top of the mixer on. Remove those and you can undo the top housing.
You take off the back of the mixer in a similar manner. Use a screwdriver to pry off the chrome cap on the back, then remove the single screw and the speed control will come off.
The gear box just above the blades is a potential area for the growling. It is pewter colored metal held in place by four screws. Clean out the old grease and replace with new (NOT oil, grease, like axle grease or lithium grease).
Use a toothbrush to get the old dust and flour off the innards of the machine. I also used a can of compressed air to blow it out and sprayed the electrical contacts of the motor with WD40.
Mine works like a champ now. Took about an hour.
Dec 13, 2008 | Sunbeam Heritage 2346 Stand Mixer
Bread hook use
Use it to the side. This will pull the dry ingredients off the bowl. If the dough is coming out lumpy, make sure you follow the recipe exactly. Putting dry into wet will give different results than putting wet into dry. If this doesn't end the lumps, try a different type of flour.
Oct 15, 2008 | Sunbeam Heritage 2346 Stand Mixer
Sunbeam mixmaster heritage series
http://www.repairclinic.comThis is a helpful website with an 800 number and they are good about helping with the fix.
You probably have to replace worn gears and or bearings.
Feb 20, 2008 | Sunbeam 2370 MixMaster Series Stand Mixer
Sunbeam Stand Mixer
For whatever reason, Sunbeam must have decided to cut on costs and used a plastic gear to transfer power to the beater. I had my Sunbeam for two years and the plastic gear decided to break. End of mixer. You cannot find a replacement part anywhere. It is the last sunbeam I will buy.
Dec 02, 2007 | Sunbeam 2350 Heritage Series Mixer
Sunbeam 2370 MixMaster Series Stand Mixer Logo
364 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
