Question about Mitsubishi CS-40307 40" TV
Mitsubisi tv CS- 40307 digital capable ?
Do i need a converter box with this tv
If you are subscribing to cable or satellite TV, then the answer is no; they will continue to send an analog signal to your TV. However if you are using an antenna to receive your broadcast, then you will need a converter. Broadcast TV (over the air) has switched to a digital signal for most of the channels as of June 12th.
Posted on Jun 22, 2009
Does this TV have ATSC digital capability or will I need a digital tuner to use a digital antenna?
If the TV is an analog only you will need to get a digital converter box to be able to use a digital antenna. You can find this online by doing a Google search or you can try Ebay they have a bunch of them 662results for tv digital converter box
May 05, 2015 | Hitachi 51F510 51" Rear Projection...
Is a curtis mathes CM19033S TV, digital capable (with digital antenna) or only analog?
To use this TV with a digital signal you need a digital to analog converter. Here is a link for a converter and one for the TV user manual.
Hope this helps.
Bob
Samsung CM19033 User Manual
Zinwell ZAT 970A Digital to Analog TV Converter Box for Antenna Use
Jan 06, 2015 | Curtis Televison & Video
Analog to digital
If this is an older standard tv it is analog only it's not capable of processing digital tv transmissions in any way by itself you will need a digital tv converter box. thats true for antenna reception or cable systems that supply a digital signal,with digital cable systems you will probably need their digital converter box over the air & digital cable converters are not compatable with each other.
Apr 11, 2014 | Televison & Video
Power was interupted to my cs-40307
not sure what switches your fiddling with but first thing is check your fuses are ok
May 02, 2009 | Mitsubishi CS-40307 40" TV
Black screen
use your remote then turn off the text messege of your tv.the black screen that you seen is for the messege but since their is no message written in the box ,that's why you see a black box.
Jan 26, 2009 | Mitsubishi CS-40307 40" TV
I have a mitsubishi cs-40307 that never powered back on.
try to check the horizontal output transistor if it is good,check up the power regulator
Jan 10, 2009 | Mitsubishi CS-40307 40" TV
Mitsubishi tv 40" cs40307 vertical shrink problem
thats problem is only a lose connection,if you know how to used a soldering iron ,solder the vertical section of your tv.
Dec 21, 2008 | Mitsubishi CS-40307 40" TV
Need to know if my tv is digital or analog?
most new tv's are digital capable...
but here is the trick the convertor box are only for those who don't have cable or satellite service if you use only an antenna to get channels then yes you will need a converter box for each tv that uses only the antenna to get channels if you have satellite or cable service then they don't need a converter box even if they have basic cable they won't need the box there channels are already digital converting now there are a few events that was in anlog but there are being converted as best as possible but you may notice the difference in the pictures betwwen analog (usaully old time movies or show even commercials) Digital (most everything now that are new stuff are digital and even in hd now)...
Nov 12, 2008 | Televison & Video
Is it ready for digital signals??
No this set isn't. I think you'll need a converter box. This is classed as an analog TV.
Aug 29, 2008 | Philips Magnavox 27MS343S 27" TV
Help-Love my 40307
I hate to tell you but if parts are not available is not a good sign,consider buying a new TV and get it over with.
Sep 12, 2006 | Mitsubishi CS-40307 40" TV
Televison & Video Logo
98 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
