Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
My powerbook g4 wont start
At first i had the blue screen with apple logo, and now i just have a lot of writing on a black screen
  • Anonymous Apr 13, 2009
    how do I get into the bios screen?
  • Anonymous Mar 27, 2014
    Powerbook G4 will not start up or complete start up. It gets to the apple symbol and the circle continues to spin
  • 40 Answers
Your computer is booting into single user mode.
Try to boot from the CD the computer shipped with.
Insert CD and restart the computer holding the "c" key
Your computer should boot.
If so run disk utility from the cd and repair the disk as well as permissions.
If this is successful your computer "should" be repaired. If it still has problems booting, Use your CD to perform a Archive and install which should keep all your personal settings and installed software intact.
Posted on Mar 01, 2009
Powerbook G4 12" 1.5 Aluminum will not boot. Apple logo and spinning wheel appear, sometimes eventually changing to a blue screen, sometimes remaining, until stopping with on/off switch. Aside from that,...
try booting with disk select option.
hold down option key and power up. Try resetting pram.
Look up key commands on apple support.
Try safe boot with holding down s key
etc....
Aug 28, 2013 | Apple OS Computers & Internet
When i insert a cd or dvd into mu MAC powerbook
Check to see if your discs are dirty. Clean them and try again. Also, check to see if you got heavy scratches on the discs. Also, click on the blue apple logo at the top of the screen, then click on about this mac,then click on more info. Under the hardware click on the disc burning title. Look at CD write and DVD write info to see what the burner will play. If no info is there, then your optical drive is disconnected from the logic board or your optical drive is toast. If your optical drive spits out every single disc, then that also means it needs to be replaced.
Nov 05, 2009 | FastMac (APP-5693) for PowerBook G4...
Powerbook G4 blue screen on start up
Basically some causes of blue screen is the RAM check the RAM remove first maybe it is clogged by the dust. Remove the dust of the memory stick and insert it back to you computer. Usually of you have this problem again you need a recovery disk. Load a windows CD to your CD drive you need to boot and repair the windows.
Regards
nicole
Oct 03, 2009 | Apple PowerBook G4 Mac Notebook
Canoot get Mac to boot up all the way
there is a hardware fault or full hdd ...
thi guys will help Micromen - London
Aug 30, 2009 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
Black screen with codes. Help anyone?
Replace your Bluetooth device if external, and have the unit serviced if the Bluetooth device is internal.
Apr 30, 2009 | Apple MacBook Mac Notebook
Powerbook won't start up
If you have the original install CD or the OSX CD, boot to CD. To do that you must insert CD, restart PowerBook and hold letter "C" on keyboard while computer is starting, then take the first steps towards installing the OS, when you get to the bar on the top go to Tool>Utilities>Disk Utilities then select the drive a do a disk repair. That may fix the problem and bring your system back to booting normally.
Mar 15, 2009 | Apple PowerBook G4 Mac Notebook
Apple mac g4 laptop wont come on
Kernel panics are not what you have, you have a flashing question mark, it indicates there is a problem with either the hard drive or the operating system on the hard drive.
Kernel panics are different, the unit tries to start and then the unit crashes with a "kernel panic"
Feb 19, 2009 | Apple PowerBook G4 Mac Notebook
Apple Powerbook G4 1.67 GHz LCD problem
Probably more like a Video cabling issue or a Screen assy getting bad connections.. Both have been seen here.
Jul 16, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple
Which screen is it stuck at? The spinning "gear"? The Blue progress bar scree? or the login screen? Answer this and i have your answer.
May 13, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
177 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
