Question about Goldstar MV-1615 Microwave Oven
Goldstar, MV1515W, builtin- fuse
Did not get a owner's manual with product. Need location of fuse. Thanks
  • 52 Answers
It is under the casing, you need to remove the casing and you will see them, large power protection and smaller control circuit fuses. the power one may be protected by a black plast sheath
Posted on Feb 23, 2009
How to install GoldStar Microwave oven Model # MV1515w
Remove all plastic wrap etc //plug it in and enjoy
Dec 29, 2009 | Goldstar Microwave Ovens
Goldstar MV1515W running but not heating
One of two things will be the problem. 1)almost certainly the magnatron. 2)the cap and HV diode need to be checked and possibly replaced.
Sep 17, 2009 | Goldstar MV-1515 Microwave Oven
Goldstar mv1502w has no power.Not even on display.
You can find the service manual here.
(Also, the owner's manual is here in case you want it)
I would suspect the magnetron thermal fuse / thermal cutout / thermostat (depending on which it has) or the oven cavity thermal fuse / thermal cutout / thermostat (depending on which it has).
To access some components, namely the oven cavity thermal device, you will need to remove the oven form the wall, in which case the installation instructions are very handy.
You can order L.G. parts from Encompass. Or you can call them toll-free at 866-779-5835.
Mar 14, 2009 | Goldstar MV-1515 Microwave Oven
Manual microwave oven model for ER-761 MD
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Some L.G. / Goldstar owner's manuals can be downloaded here.
Nov 19, 2008 | Goldstar Microwave Ovens
LG ms-304ez microwave
I would suspect the fuse or the thermostat.
The fuse should be located on a filter board near the back of the unit where the cord comes in.
The thermostat should be located on the left rear corner of the chassis above the cooking cavity.
We have two service manuals for this type of model and have uploaded them to our site here and here to help you.
You will need the free Acrobat Reader to view or print them in case you don't have it already.
Since these are not exactly the same models as yours, the part number for the thermostat may not be the same. You should verify them with the distributor.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
Formore Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat8-5 CT) and choose the appropriate prompt from the menu or visit here.
Oct 30, 2008 | Microwave Ovens
I need a copy of installation directions for an over the range microwave Gold Star model mvh1615ww. Can anyone help? Thanks
If yours in not there, for more Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Sep 27, 2008 | Goldstar Microwave Ovens
I have a over the range microwave and I need the support bracket the holds the unit up. where can I get one. model number is goldstar MV161OWW is there anywhere where i can order? and it there a...
That model should be MV1610WW.
Sep 25, 2008 | Goldstar Microwave Ovens
Microwave has no power
I'd say the thermostat and/or fuse are blown. I just hope the magnetron survived.
I don't have that exact model's service manual but ones before and after only used one thermostat, similar to the drawing below.
They also have a fuse, usually located in an inline fuse holder connected to the power cord inside.
Aug 21, 2008 | Goldstar MV-1515 Microwave Oven
Need help with my Gold Star microwave.
The owner's manual won;t tell you that, only the repair or service manual.
While we don't have that exact model, we do have the manual for a similar model uploaded here.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Aug 06, 2008 | Goldstar MV-1515 Microwave Oven
Goldstar MV-1615 Microwave Oven Logo
412 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
