Question about Marvin W.B. 5060M QUARTZ STEAM 'N HEAT 1500-WATT RADIANT HEATER W/ FRAGRANCE FRESHNER
I have a marvin fragrance freshner portable electric heater model 1500. I wanted to know if there is a certain fragrance i can use in it? i've been just putting water in it
5 Suggested Answers
SOURCE: Marvin Model 3150 Electric Portable Room Heater
No I DID NOT GET A PHONE NUMBER TO CONTACT MARVIN MFG AND THE LINE IS BUSY. I DID NOT FIND THIS SERVICE, FIXYA, HELPFUL AT ALL.
I am not going to pay $29. or whatever for Expert Advice when you can't even give me a proper phone number to call the company. The heater didn't even cost that much. I can throw it out and buy a new one. What I ask for was not Advice but a PROPER PHONE NUMBER for Marvin Manufacturing and you could not even supply that.
Posted on May 23, 2008
SOURCE: nonheating marvin, model 5000, quartz heater
Yes, I got my Marvin, model 500 quartz heater fixed, thank you. Please discontinue further communication.
Posted on Nov 30, 2008
SOURCE: Marvin Quartz heater element
Just ordered the equivalent of Marvin part #E1750 from Quartz Infrared Inc. Their part # is 50909 and is $17.95 Phone # is toll free 866-747-4328
Posted on Jan 04, 2010
  • 10 Answers
SOURCE: Need Marvin Heater replacement element (model 2060)
Marvin replacement elements are available from Quartz Infrared for $17.95.
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
Posted on Jan 07, 2010
  • 10 Answers
SOURCE: Need Marvin quartz tubes
Marvin Replacement elements are available from Quartz Infrared Inc for $17.95. You can order them directly here:
Is it safe to plug a 1500 watt Marvin quartz radiant heater, model 4940 into the same receptacle as a lamp with a 100 watt bulb ? We had both appliances plugged into the wall and started smelling smoke...
You had a low end cheap receptacle more than likely or possibly a loose wire on the receptacle. You should have #12 wire fed from a 20 amp breaker and a 20 amp spec grade receptacle.
I am a licensed electrician with 30 years experience. IBEW LU #479 Beaumont TX.
Nov 19, 2010 | Marvin Quartz Radiant Heater
The rotary switch failed and I need to replace it. I can not find the part in quantities of less than 2000. How do I buy replacement parts?
simply locate the company you will get the exact part u want,or get the manual that came with it u may see the company contact
Apr 07, 2010 | Marvin Portable Electric Radiator Heater
The rotary switch off/750/1500 is bad. Marvin 2060 quartz heater. any replacements?
replaced the rotary switch with a double poll single T. this makes the heater a 1500 watt with no 750 watt option.
Feb 05, 2010 | Marvin 2060 Compact Heater
No problem just would like to know where i can buy replacement bulbs.
Take the bulb out, take it to a appliance parts place or your local Ace or other fine hardware store for fast replacement.
Thanks for your question at FixYa.com
Jan 15, 2010 | Marvin W.B. 5060M QUARTZ STEAM 'N HEAT...
Dec 12, 2009 | Marvin 2060 Compact Heater
No heat or fan operation
24/7 Appliance Repair @ (608)214-5632 we are located in southern wisconsin, Thank You
May 26, 2009 | Marvin 3150 Mid-Size Heater
Heater fan noise
trw www.sears.com the parts dept...have make and model ready!
Dec 10, 2008 | Marvin 2060 Compact Heater
Nonheating marvin, model 5000, quartz heater
Nov 29, 2008 | Marvin Quartz Heater With Built-In...
Nov 23, 2008 | Marvin 2060 Compact Heater
May 21, 2008 | Marvin Portable Electric Radiator Heater
Heating & Cooling Logo
85 people viewed this question
Top Marvin Heating & Cooling Experts
Bruce Showalter
J.D. Browning
J.D. Browning
terry stevens
Are you a Marvin Heating and Cooling Expert? Answer questions, earn points and help others
