Question about IBM ThinkPad T21 Notebook
Thinkpad T21 Usb Modem problem
Hi, I have problem with my USB modem. It's cricket usb modem, and before it worked fine. After re installation of laptop i set up drivers and i connect on internet but after 2-5 min it cannot receive connection. I checked if is because serial port, it is on com4. I turned off serial port in bios, and still same. It shows some error on modem log. It shows like it couldnt receive conection. Also modem worked on other computer, and i use wind xp. Drivers that i downloaded are from Lenovo web site.
I need help.
Thank you
I have a Cricket USB Modem. It successfully installed on the computer, but, when I try to log on, it says that the device is "not found." Is there something that I am not doing/need to do?
HI Gmp6329 go to the control panel of you PC. In the control panel you are looking for device manager. Under the device manager look for the cricket modem and see if has a yellow ! point. if you see this uninstall the modem. Also if there is a disc that you need to install make sure it is the latest version. You can go to and download it to you PC.
Mar 27, 2011 | Acer Aspire One PC Notebook
It wont let me get internet i have cricket broadband the usb device
Hi Nicholas,
My name is Ryan and I work on behalf of Cricket. If you are experieneing issue with connecting to the internet using your Cricket broadband USB modem, please view the steps below in order to speak with a customer service member directly regarding solutions and area coverage.
Please call Cricket Broadband Customer Service Center at 1-800-CRICKET.
*Before contacting our Customer Service team, please ensure you have the following information:
-Operating system (i.e., Windows XP)
-Cricket Wireless Modem Device number (MDN) assigned to your wireless modem. To find your MDN please use the following steps:
  1. Insert the device into your computer's USB port
  2. Open Cricket Broadband Connection Manager
  3. Go to Help>About, your phone number is listed as your MDN
More FAQ and help can be found on
Ryan on behalf of Cricket
Feb 15, 2011 | Nintendo Wii Console
Can I connect my USB Modem to my Belkin n300 Surf? do I need an adapter to connect it??
It is not possible to connect your USB modem to belkin router... You need to run an ethernet cable between the modem and router...
Belkin routers are not compatible with USB modems like cricket broadband, MTS Mblaze modem etc...
Jan 23, 2011 | Belkin Wireless Surf Router (F7D2301)
What type of modem do i need to connect my xbox 360s wifi to a cricket broadband usb modem
You don't need a Modem you need a Router, a USB router, they they have them at Radio Shack,Best Buy, etc. or just Google USB Router
Jan 13, 2011 | Microsoft Xbox 360 Console
If you dont have a router can u still use a cricket usb modem
with a laptop connect the laptop to ps3 with an ethernet cable and on the cricket modem connection goto properties and turn on connection sharing and choose the local are connection as device to share with
Oct 22, 2009 | Sony Playstation 3 (PS3) Console
USB reads wireless modem, software doesn't!
mac doesn't support any data card till date so this is not working . if you want to connect it install windows using bootcamp then your problem will be solved. if something importent rate this article
May 09, 2009 | Apple iBook G4 Mac Notebook
Hi i have usb modem of tata indicom which is not working properly.
ok u have tata indicom in this usb modem u have cd with this for tata indicom usb modem driver first u have to install this cd in computer after this use the modem other wise the modem not working...ok pls install the usb modem cd in your computer.
Apr 01, 2009 | Computers & Internet
Epivally CDMA USB modem
I have purchased recently a USB wireless internet service from forton modem . The USB modem is not working the desktop but when I try to install the USB modem on my computer
desktop massage display error 797
Epivally cdma driver not installed
Is any component - driver missing on laptop as it was formatted earlier.
Please reply
Mar 13, 2009 | Computers & Internet
How to install hi-speed usb to T21
You don't have the hardware, when you do, xp will install the driver automatically. You can get a PCMCIA card with usb 2.0 and plug it in the slot in the side, around $15 should do it and it is over 20 times faster than 1.1
Mar 12, 2009 | IBM ThinkPad T20 2647 Notebook
Pentium III 800 mhz T21 Thinkpad Internet connection problems
why fight it , let it be on com 1 then,
go into the bios and disable the serial ports .
that may be the easiest fix as long as you don't need the serial port for anything.
but if you have a serial mouse oh boy.
May 13, 2008 | IBM ThinkPad T21 Notebook
IBM ThinkPad T21 Notebook Logo
189 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
