Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Needle hitting metal casing .. Singer Futura CE 200
I have the walking foot on my machine. My needle was hitting the metal casing for the bobbin. I changed needles thinking it was bent, but that did not resolve the problem. I also changed the foot back to the regular. I am using needles specific to my machine. I took the metal plate out and cleaned everything well just in case. But I always maintain my machine. Nothing I do is helping....any ideas? In need of HELP!!
  • 23 Answers
It happend to me aswell , not getting the source of the problem!
Then I noticed that the bobbin casing was out of the original position, take the whole casing out and make sure that when you put it back that the small metal tension loop at the front side on the right is correct, this image you can see in your handbook, (placement of the bobbin casing)
Posted on Feb 27, 2009
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
Can a twin needle be used with the Futura ce-200?
If the needle plate and presser foot are wide enough to accommodate the double needle, then you can use it.
Make sure the needle position is center and the stitch type is straight stitch.
Hand walk the needle at couple of stitches to be absolutely sure all is clear.
Mar 13, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer CE250 Futura problems with timing and bird nesting
Needle could be loose or bended or use another size. Put the needle all the way out and the insert a new one inside making sure is the right way in (flat part hasto be looking oposite of you).
another thing is that the Tension could be too tight.
Last, Rethread the machine with another thread to make sure is good.
Hope it helps
Feb 17, 2010 | Singer CE-200 Quantum Futura Computerized...
The thread and bobbin are nesting up in the bobbin case
Two things I have found that make my singer ce-200 nest. 1st. When I change threads, sometimes I thread it wrong - always nests when I do that. 2nd. When the bobbin runs out of thread it always nests for me, so I have to check the bobbin often. And I remembered a 3rd thing. 3rd. The area for the bobbin & bobbin casing has to be clean, no pieces of threads, and the bobbin casing itself can move, so make sure it's seated correctly.Whenever I get nesting, I take the metal cover off, under the needle, to get in and clean the bobbin area and under the needle good, before I go back to embroidering.
Oct 28, 2009 | Singer CE-200 Quantum Futura Computerized...
Needle hits the plate that is over the bobbin.
If possible hoop the item. I have found that any item that has any thickness causes the presser foot to be pushed forward and the needle hits it and breaks. If you can press the item to lessen the thickness this may help. I spoke to Singer (I am a Singer dealer) and they did not have any help for this other than to recommend that the owner cut out the back of the foot. I don't think that would be a solution as it would be difficult to cut out the back of the foot and still have smooth edges, also it would cause the foot to be weak and possible break or bend. Good Luck
Feb 25, 2009 | Singer CE-200 Quantum Futura Computerized...
Top thread not looping the bobbin thread
In your case, I believe that the needle height is out of adjustment, and it's an easy fix. Insert a #14 needle, and make sure that it is ALL the way up in the clamp. You can determine that by looking at the shaft right above the clamp; the needle end should be resting against what looks like a grey bar.
Next, take 10 pennies and stack them on the needle plate. Your machine's needle should JUST be resting under the needle; it should be a tight fit. If it's off just a "smudge," leave it alone. If it isn't, take the cover off the needle area, and locate two Allen screws on the needle shaft. The one that adjusts needle height is the bottom one, and you should only loosen by about 1/2 turn -- not take it off. Adjust to the 10 penny standard, then make sure that the eye is exactly to the font, then tighten.
Mar 09, 2017 | Singer CE-200 Quantum Futura Computerized...
A brand new Singer Quantum Futura CE 200 Sewing/Embroidery machine, have not been able to embroider or sew a single stich, all I have been able to do is wind the bobbin. When I'm going to start...
Dear Magarita, The safety device is activated when thread gets entangled around the bobbin case. First check by removing the plastic see-through plate. If necessary remove the 2 scews on the metal needle plate and remove the bobbin case completely. Put it back and test by turning the handwheel. It should turn freely.
Hope this solves your problem.
Dec 08, 2008 | Singer CE-200 Quantum Futura Computerized...
Needle keeps hitting bobbin case on my Singer CE 100 Futura, it is now jammed completely. Why is this?
either your bobbin case isnt installed right or the machine's timing is messed up try to get needle loose or completly out is preferred then try turning it and see if it comes unjammed if so take your bobbin case out and reinstall it making sure it is in the fit right if this dont solve it then you need to get timing set (not recommended to do at home get pro to do it ) hope this helps you
Aug 20, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
405 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
