Question about LG WM1814CW Front Load Washer
My LG WD8074FHB is saying SE what does that mean
  • Anonymous Mar 19, 2009
    I have the same problem. The User Manual has all sorts of code except 'SE'.. help!!!!
  • anna r May 14, 2009
    LG intellowasher WD-8090FB is saying "SE" WHAT DOES THIS MEAN? HELP!!!
    Problem Solver:
  • 13 Answers
Call 1-877-714-7486 for free LG help.
Have Model and S/N
Reset machine and Check again.
Posted on Sep 02, 2009
5 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: lg model wd8074fhb error code
you have a blocked pump,Remove the lower front panel ,remove the pump hoses and clean out pump/hoses.Please rate this , Thanx.
Posted on Jun 05, 2008
  • 53 Answers
SOURCE: LG INTELLO WASHER WD8074FHB HAS A ERROR SE
oh dear, code SE indicates a motor fault could be expensive.
Posted on Oct 16, 2009
greyrider
  • 35 Answers
SOURCE: lg wd8074fhb will not rotate drum on was or rinse
LE=Load Error CE=Cycle Error
Unplug at socket for two hours will reset the Error Sensors. The sensors are there to prevent overheating of the motor and the possible risk of a fire.
Load Error is linked with too much weight in the drum. Cycle Error is limked with an uneven load.
If it happens again, unplug for two hours to reset the Error Sensors.
Hope this helps.
Posted on Nov 16, 2009
  • 343 Answers
SOURCE: main circuit board faulty
SE is 'sensor error' This could be anything from a loose wire to a faulty Hall sensor or even a main board failure......You probably need an LG technician. Your machine sounds like it's worth repairing.. Get quotes.........Good luck...Nomess
Posted on Jun 02, 2010
Testimonial: "thanks so much for your help"
Lg intellowasher 7kg wd8074fhb
The water pump can be a source of a leak.
Oct 29, 2013 | Washing Machines
Main circuit board faulty
May 30, 2010 | LG WD-16115FD Front Load Washer
Lg wd8074fhb will not rotate drum on was or rinse
Hope this helps.
Nov 16, 2009 | LG Washing Machines
What does SE mean on my LG Intellowasher 7kg WE-8074FHB display
Error SE is a sensor problem as per LG support.
you need to change the senser of your machine...
Good Luck!!
Mar 22, 2009 | LG Washing Machines
Error code SE on LG washing machine means what?
SE is a sensor problem as per LG support. I will post a follow up after I have recieved the technician in 2 days
Oct 19, 2008 | Washing Machines
LG intello WM12235
SE error code means a communication problem between the display controls and the main control board.  You will need a qualified LG technician to locate and repair the problem.
Jun 09, 2008 | LG WM-2277HW Front Load Washer
Lg model wd8074fhb error code de what does it mean
Jun 05, 2008 | LG Washing Machines
It probably means System Error. Have you tried a simple reset. Pull the machine away from the wall carefully, make sure you do not have wet hands or feet, etc and unplug it from the wall. Leave it unplugged for 20 minutes. (Also check to see if it is plugged into an outlet with a little red button on it? is the button pushed in? It should be? ) After the wait, plug the washer back in and see what you have. I hope this helps.
May 22, 2008 | LG Washing Machines
LG intellowasher (front-loading washing machine) is starting to squeak.
I suggest u buy another washing machine. This one's had it!
Jan 12, 2008 | Washing Machines
LG WM1814CW Front Load Washer Logo
207 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
