Question about Lexmark X7170 All-In-One InkJet Printer
INK CARTRIDGE I bought a #32 lexmark black cartridge and machine relays message to me saying that I have a #1203 ink cartridge error.  What does that mean.  Are ther different #32 lexmark cartridges?
  • Anonymous Mar 02, 2009
    I bought a black ink cartridge because it was low. My color is low too but I didn't replace it yet, and I am having the same issue(1203). It seems to work sometimes. I wish I could figure out what's wrong!
  • 408 Answers
Http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:439:0:0&docid=ENUS21870
it is a known issue.  Try cleaning the contacts with alcohol and qtips on both the printer and the printer cartridge.  If that doesn't work, it may be a faulty ink cartridge or a faulty carrier.
Posted on Mar 03, 2009
Printer would not print. Says see error #1203 in users guide.
By any chance is your printer a Lexmark?
1203 Error Message indicates a problem with an ink cartridge. Can be a communication failure between the printheads (cartridges) and the printer or a short in one of the printheads.
Commonly occurrs with refilled ink cartridges and indicates the cartridge has been overfilled.
If powering off and restarting the printer does not correct the problem, to remedy, remove the ink cartridges, check for leaking or excess ink on the cartridge contacts; clean the cartridge contacts using a water dampened q-tip. See for illustrated instructions:
http://support.lexmark.com/index?page=content&id=HO2322&locale=EN&userlocale=EN_US
If the problem is with over-filled cartridges, to avoid a repeat, you may need to wick out some excess ink by placing cartridge on a damp paper towel.
If these steps do not resolve your issue or your problem is not with a Lexmark printer, please reply with the make and model number of your printer for an alternate solution.
Thank you for using FixYa!
Dec 01, 2011 | Office Equipment & Supplies
Printer says error #1203 what do I do
Problem Error 1203 ; 1203 error message; 1203 cartridge error; Cartridge short error Solution Overview
The 1203 error message is caused by either a communication failure between one of the printheads (cartridges) and the All-In-One (AIO), or by a short in one of the printheads.
Resolution
  • If the problem occurred immediately after the printer was purchased and unpacked from the box, please contact Lexmark Technical Support for assistance.
  • If the problem is occurring during the normal printer lifetime, the procedures below will help you to resolve it.
Troubleshooting a Communication Error between the Cartridge and the Printer click on this link and follow the steps listed, hope this helps! http://support.lexmark.com/index?page=content&id=SO3683&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=LEXMARK_X5495&searchid=1286737658844 Please leave rating ;) thanks
Oct 10, 2010 | Lexmark X5495 All-in-One &USB...
Printer says cartridge error: error 1203
Remove both ink cartridges and check the bottoms to be sure all of the tap is removed. Small pieces of tape frequently are stuck to the cartridge bottom causing errors. Confirm you have the correct cartridges (# 34 for Black(HIGHYIELD) and #33 for color). Reseat the cartridges and try again.
Sep 06, 2010 | Lexmark X7170 All-In-One InkJet Printer
Cartridge Error # 1203 when replacing black ink cartridge
It sounds like the printer thinks it is not a genuine ink cartridge. Fit a Lexmark cartridge to cure it.
Jul 16, 2010 | Lexmark X8350 InkJet Printer
IT KEEPS TELLING ME THE RIGHT CARTRIGE IS WRONG, ERROR #1203, WE LOST OR OWNERS GUIDE
Here is what Lexmark says:
Cartridge Error: 1203 Your print cartridge has a short.
  1. Press Power to turn your All-In-One off.
  2. Unplug your All-In-One from the wall outlet.
  3. Plug in your All-In-One.
  4. Reinstall the cartridges.
If this does not resolve the problem, see More troubleshooting options, or replace your cartridges.
Also the cartridge that should be installed looks like Lexmark 32 ink for black and 33 ink for color.
Mar 25, 2010 | Lexmark X5470 All-In-One InkJet Printer
I ordered Lexmark 32 & 33 ink cartridges off ebay (but they are not 'genuine'). I'm getting an error message #1203 - 'Consult your user's guide'. Does my Lexmark X7350 only accept Lexmark brand...
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Nov 30, 2009 | Lexmark X7350 All-In-One InkJet Printer
Changed out black ink screen says insert
It will be a hardware printing problem mostly. Try cleaning the parts with alcogol or/and elastic rubber. Also try to increase the force of contact with a sticky tape or like that.
Aug 09, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark x9350 printer gives error message #1203
I logged into Lexmark's web site and checked their printer support page. It said that if you get error message 1203 your ink cartridge has leaked fluid. In order to find the right cartridge, do the following. Remove both ink cartridges, put in one, turn off the printer, turn it back on and if you get the message 1203 that's the cartridge with the problem. I did not get that message. I turned off the printer, put in the other cartridge, and turned it back on. Sure enough, I got the 1203 message again. (I had cleaned the wrong cartridge before). I removed the leaky cartridge, cleaneded it (making sure I did not leave any residue) and put it back in the printer. It worked!
Jun 13, 2009 | Lexmark X9350 All-In-One InkJet Printer
Cartridge error
How I solved this problem was, I took out the color cartridge (which seem to be the one giving the error message) and worked only with the black ink (and chose print black and white )
My color ink cartridge had been refilled at Walgreens. The Black ink cartridge is an original Lexmark
Oct 22, 2007 | Lexmark X3480 InkJet Printer
Error #1203
Normi, The 1203 error as you suspected deals with the ink cartridge. This is a common problem and Lexmark has a troubleshooting procedure posted on their web site. Here is the link for the web page. http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&emeaframe=&docid=ENUS21870 Hope this solves your problem and please don?t forget to rate this posting.
Jan 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X7170 All-In-One InkJet Printer Logo
100 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
