Question about Amana ALE230RAW Electric Dryer
Blowing high limit fuses
I posted the problem a few weeks ago and I was told I might have a blockage but I do not, I took apart the vent from wall and the entire exhaust system in the dryer and found nothing. This time the fuse only lasted 1-2 weeks and in the past it lasted a month or so, would it be the thermostate or the thermostate heater? I have no clue anymore, can you help my model number is lea30aw if you need it thanks
  • mraith Mar 06, 2009
    I have replaced the high limit fuse three times now and the space between replacements has decreased each time. I noticed this time that there is current (120v) running in the top wire that connects back to the thermostat and then the upper post of the element. I followed the wire back to the controls and found that it connects to a resistor and then to the controls. The resistor is supposed to test at 4.7kolms, and did, so I'm guessing this is a failed control module.
I HAVE A AMANA LEA30AW DRYER I KEEP BLOWING THERMAL FUSE THE HEAT ELEMENT TEST GOOD AND THE VENTING IS CLEARD WHAT COULD CAUE IT TO BLOW
Posted on Mar 18, 2011
  • Amana Master
  • 3,361 Answers
Check the blower wheel attached to your motor.
It may be free-wheeling causing too high a temp thet is blowing the fuses.
Posted on Feb 22, 2009
Heat will start for a few minutes then stop and dryer will continue to spin with cold air.
You must have a blockage in your vent line between back of dryer to the outside or a kinked vent hose or a blockage in your blower wheel cover.
Jul 16, 2015 | Samsung DV448AGP 7.4 Cu. Ft. Gas Dryer -...
I have a Kenmore series 90 dryer about 15 years old which stopped heating last week. I found several videos on you tube which detailed the steps to troubleshoot and repair. The steps were to check...
Blown high limit fusees can be caused by.
  1. Not enough airflow caused by blockage in the exhaust vent pipe.(most common) Check for strong airflow coming out of the back of machine, then check for good airflow at exterior vent. Clean vent if airflow is restricted.
  2. Bad drum seal
  3. Dirty lint screen
  4. Broken blower wheel
  5. Blockage inside the machine.
Jul 19, 2011 | Kenmore Dryers
Dryer became very hot and then shut off and will not turn back on Maytag model MDE9420AYW
Refer to part #11 on diagram #4 to see where the thermal fuse is located. The thermal fuse and the high limit thermostat must be replaced.
You must find and correct the vent blockage problem or you will blow out the new parts.
Check the vent system inside the dryer. Check the connecting vent from the dryer to the wall connection. Check the through the wall connection. Also check the blower wheel attached to the motor. It could be stripped and slipping on the motor shaft.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45466&diagram_id=647881#d647881
Jan 01, 2010 | Maytag Dryers
It starts and runs fine but wont heat up
The most likely cause for this problem is the thermal fuse, or high limit as it is called. They are designed to blow if the temperature gets to a dangerous level. The excessive heat is usually caused by a lack of airflow over the element, the culperate for this is usually excessive lint somewhere in the venting system. It could be the dryer hose, the vent cap, but also could be within the dryer. I've seen it packed in the area just passed the lint filter packed so tight I had to scrape it out with a putty knife and then wash out the rest. This can also be caused by a damaged blower motor wheel (lack of airflow, which will overheat the dryer and blow the high limit) though the blower wheel is usually the least likely problem.
Generally it is a blockage in the venting system or used with lots of cloths and a plugged lint filter that causes the high limit to blow. The high limit fuses aren't expensive. Get the model and serial of your dryer and check the web for high limit/thermal fuse, they cost approximately 12-25 dollars.
A simple continuity test with a test light or multimeter will tell you if it is good or not. (fuse) MAKE SURE IT IS UNPLUGGED if/when you try this. They are located on the back of the unit under the back cover towards the bottom. Most units have 8 or so screws holding the back plate on.
Hope that helps.
Oct 27, 2009 | Whirlpool Dryers
Thermal fuse repeatedly blows
The thermal fuse or high limit thermostat failure generally points to a reduction of air flow due to SOME blockage either inside the dryer or in the vent pipe leading out of the house. If you find either of these parts bad be sure to check the vents after replacing parts to ensure the same parts won't fail again.
It sounds like you have blockage in SOME area of the venting system, either interior to the dryer or in the vent pipe leading out of the house. The thermal fuse is a safety feature to warn of low air flow. Remove vent from wall and run dryer placing hand over end of hose to determine strength of flow difference after attempting to do the same thing at the exhaust outside the house. Good Luck.
Sep 04, 2009 | Kenmore Dryers
I have a maytag dryer, fairly new and not used that much. It is overheating and shutting off. This weekend, we took it apart and found sand in the lint trap and cleaned it all out. The vent is clean too....
check the entire exhaust system for blockages. check all components that make up the entire exhaust system. this includes the vent hose and blower assembly as well. if the exhaust system if free of obstructions, this will confirm a faulty High limit thermostat. replace this failed component asap. During the exhaust check, make sure when the unit is drying that, it is blowing at a high rate. you should feel a good forceful air flow out the vent. if its weak, you will need to clear the blockage.
Jun 15, 2009 | Maytag Dryers
2007 FORD SPORTS TRAC BATTERY KEEPS DYING
180 milli-amps is way to much draw,ford's limit is 50 milli-amps but typically we usually only see around 20-30. Now when you say fuse 2 is that in the under-hood fuse panel or the interior fuse panel? And if this vehicle is a 2007 it may still be under factory warranty which was 36 months or 36000 miles providing that the add on automatic starter is not causing your draw.Which in that case the people who installed it should be responsible for that.
Mar 05, 2009 | 2007 Ford Explorer Sport Trac
My dryer stopped working, using a multimeter I determined that the thermal fuse was open. I unclogged all the ducts then ordered a high limit thermal kit. After changing the fuse, it blew-up on the first cycle. It turns out that even though the high limit checked ok, it was defective. After changing both the fuse and the thermostat(included in the kit $25), the dryer worked correctly.
Feb 05, 2009 | Amana ALE230RAW Electric Dryer
Hotpoint NVL333EY Electric dryer blows thermal fuse
I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
Jan 04, 2008 | Hotpoint NVL333EY Electric Dryer
Amana ALE230RAW Electric Dryer Logo
358 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
