Question about GE (PSS26MSRSS) Side by Side Refrigerator
PSS25NGMA -- Stuck on crushed ice
The dispenser interface is stuck on crushed ice and will not switch to cubed ice or to water. All of the other buttons continue to work, including Quick Ice, Lock, Light, etc.
When the cubed ice or water button is pushed, there is an audible beep, but the function does not switch.
I performed a system reset using the diagnostics mode outlined in the service manual and this did not help.
I have seen a similar post where replacing the circuit board behind the dispenser was recommended, but I'll be darned if I can find it again to see if that was a successful solution.
Thanks in advance for any assistance. I am handy with a multimeter if that could make a difference.
  • mattburnside Feb 23, 2009
    Jumptrout51:
    We pulled out the ice bin and emptied it completely to make sure the auger was inserted properly and turning. Problem persists. Thanks!
  • Anonymous Mar 05, 2009
  • GE Master
  • 3,361 Answers
Pull the ice bin out and re-insert it.
Posted on Feb 22, 2009
  • steve
    steve Feb 23, 2009
    Sorry to tell you this but, your main control board has malfunctioned and must be replaced.
Getting shaved ice instead of cubes
Several possibilities, but check first for cubes that are too small (means too little water is coming in during ice maker fill) and those cubes fracture into smaller bits when they are dispensed.
Another possibility is the cube/crushed plate inside the dispenser is stuck. This is a curved plastic piece that lies next to the crusher blades inside the dispenser head of the ice storage bin. For cubes this place must be retracted (swing away from) the crushed fingers to allow the cubes to pass without being broken up.
Oct 30, 2016 | Refrigerators
Ice cube stuck on crush
remove the ice bin,there must be a chunk of ice blocking the cubed dispenser chute of the dispenser and channeling all ice thru the chopper chute,run hot water thru it to melt any chunks blocking the cube chute,then dry it and let it get cold before filling with new ice or you will have the same issue again
Aug 12, 2012 | Frigidaire Refrigerators
Water and ice cube dispenser working fine, crushed ice not crushing. 26 cuft side by side model MZD266SHES
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid. Crushed ice is the default position and the solenoid is energized to cube ice.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Feb 21, 2011 | Maytag MFI2568A Side by Side French Door...
Dispenses crushed ice instead of cube ice
Aug 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
Aug 17, 2009 | Refrigerators
LG fridge freezer GR-L207QVJA. The ice dispenser gives a choice of crushed ice or ice cubes, but has stopped dispensing ice cubes and gives crushed ice on both settings.
Jul 01, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser only dispenses crushed ice
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Nov 05, 2007 | Frigidaire FRS26KF5C Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
206 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
