Question about Casablanca Fan Stealth 3211T Ceiling
Casablanca Stealth 3211T stopped working
We purchased a house and the Casablanca Stealth 3211T in the master. The fan stopped working several months after we moved in and our home warranty purchased the new model to replace it. We installed the new fan (Casablanca Stealth 3211A) using the old canopy and pole but the new fan will not turn on when we tried with the new remote. The old Stealth had the Inteli•Touch wall control but the new one has the Advan•Touch remote. Now that we have the Advan•Touch remote the wall control is no longer of use to us. I realize that the two are not interchangeable--do we need to change the wiring before our new fan will work?
How do I op beeping of my Casablanca stealth fan Bulb is burnt and I removed he burnt bulb. would not top annoying beeping
Replace the bulb. If you are going crazy while getting a new bulb turn off the breaker for the room. A serious design flaw, I would complain to Casablanca if you have the time.
Oct 05, 2014 | Casablanca Fans Casablanca Contemporary...
Ceiling fan wire diagram model cd 52
Don't understand the question. Has built-in light.
Sep 03, 2014 | Casablanca Fan Stealth 3211T Ceiling
Casablanca fan-how to replace flywheel?
You'll need a special tool to take it off. Check www.casablancafanco.com for the nearest service center.
May 07, 2013 | Casablanca Fan Stealth 3211T Ceiling
Can't removed the glass to change light bulb!!!!
Try using an oil filter band style wrench wrapped in a towel.
It it breaks,that's OK-you won't get bloody.
Mar 02, 2013 | Casablanca Fan Stealth 3211T Ceiling
The glass light cover falls off when the fan is on. I have made certain that the cover was screwed in properly but the vibration of the fan loosens the cover. Any suggestions?
I would first tighten any screws that might be part of the vibration problem. They do work loose. As far as the globe goes, sounds like you might need some kind of spacer material between the glass globe and the frame it screws into. Perhaps a few pieces of small clear plastic hose. Try and wedge them between the globe and metal frame when screwing the globe back on. Make sure it is snug, but do not over tighten to the point where the globe breaks.
Aug 27, 2010 | Casablanca Fan Stealth 3211T Ceiling
Casablanca stealth fan light scrapes against blade surround
There are two probable causes. One, the light housing has been pushed/bent up into the rotating assembly, which is possible if the fan were ever removed from the ceiling and sat on the glass.
If it has never been removed however, the most likely cause is that the Allen Set screw on the flywheel has loosened allowing the flywheel to slip down the motor shaft. It's a purely mechanical problem and if memory serves, to get to the flywheel, you remove the light pan and it's right there. Find the set screw, loosen it enough so that the flywheel is easy to move up and down and raise it up a bit and then cinch it down tight. It's a fairly common problem and for the life of me I cannot understand why Casablanca would not use loctite on that set screw. I mean you pay $500+ for a fan, it should outlast you, right?
Jun 03, 2010 | Casablanca Fan 3245T Ceiling
Wiring for ceiling fan
Since ceiling fans can be wired a number of ways, typing all directions would be tedious and diagrams are better anyway, try this link.
If that's no help to ya, just repost on this problem and I'll follow up with more help.
Mar 03, 2009 | Casablanca Fan Stealth 3211T Ceiling
Scraping sound inside casablanca stealth fan
You need a new flywheel. Go here: http://www.bostonplus.com/parts.html#flywheel
Jan 24, 2009 | Casablanca Fan Stealth 3211T Ceiling
Ceiling fan light flecker
Grinding indicates failed bearings. This is causing excess load in the motor and that is causing the flickering. This is not a user repair and would like cost around $130.00 for labor and bearing assuming you find a shop willing to do it. Most fans have pressed bearings and are very cheap.
Sep 02, 2017 | Casablanca Fan Stealth 3211T Ceiling
Clicking sound
The fan should be replaced. The bearings are getting worn out.
Jerry G.
Jun 06, 2008 | Casablanca Fan Stealth 3211T Ceiling
Casablanca Fan Stealth 3211T Ceiling Logo
189 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
