Question about Bissell 3576 CleanView II Bagless Upright Vacuum
What needs to be done to change the motor on a 7901-1 ? I think it has bad bearings.
    Problem Solver:
  • 8 Answers
Sorry i messed up the first time re place the berings and it should be fine
Posted on Feb 22, 2009
Rainbow vacuum repair
May be a bad bearing and possibly be serviced by a dealer. I think the newest models don't have bearings.
Apr 04, 2014 | Vacuums
7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum: I have a Bissell 7901-1. I need to replace the pum...
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
78iiry
May 17, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Model 7901-1 bissell proheat motor runs but won't squirt or ****, just quit 1/2 way thru carpet.
heatman101
ghd
Apr 11, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Change belt on Bissell 7901-z
heatman101
eyj
Apr 23, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
NO SUCTION
If you have no suction, there are only a couple of things that could cause it. As you have checked for blockage, and changed your filters, you may have a vacuum motor with bad bearings, or broken fan blades (inside/on the vacuum motor). Either symptom points towards a vacuum motor being bad and needing replaced.
Jan 21, 2009 | Electrolux Central Vacuum
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix know. Pump is bad.
Oct 11, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 3576 CleanView II Bagless Upright Vacuum Logo
32 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
