Question about Lakewood LAKQTV22 Utility Heater
Cracked unit/need replacement
One of the unites cracked. should we run the heater? and where can we get a replacement unit?
  • 34 Answers
Visit this page for Lakewood service center info and parts http://www.lakewoodeng.com/html/parts.html
Posted on Apr 18, 2009
Master 165000 btu heater
pump cracked or main air line can b checked by turning on heater and blowing through the line coming off the back of the heater if u get fuel and flame then start looking for line cracking and or pump cracked on the back of unit pre sprung filter and the main between the plastic and the metal pump housing
Dec 09, 2013 | Heating & Cooling
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
My reddy heater 115 pro starts, but shuts off after about 5 seconds of running , i replaced the filters and nozzle about 2 years ago
Here is a service manual:
http://www.desaparts.com/service_manuals.html
If the flames actually starts but the unit shuts off after 5 seconds you need to check the pump cover on your heater to make sure you have no cracks in the rear cover.
This could be from low pump pressure but most often this problem is caused from a defective control board.
Oct 03, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Put in new thermostat, heater still blows cold
The heater control valve is most likely stuck.
Under the hood, find the heater hoses and follow them to the firewall. One of them will have a valve unit, controled by vacuume. Insure the vacuume hose is connected not cracked or broken. If not the unit itself may need to be replaced.
Could be you can open it (temporary) by hand to make sure it's the problem.
Dec 18, 2009 | 2001 Buick LeSabre
Rheem tankless water heater wont lite
the system was not sized properly, you need to have a 3/4 gas line to the unit for the volume of gas it needs, the tankless water heaters need to have every bit of gas that is says, it sounds like who ever installed di not make sure you had enough gas comming in the house, you might have to either have a new meter installed or run the gas lind directly from the meter to the water heater and cap off the gas line thats there
May 05, 2009 | Rheem Tankless Hot Water Heater...
Ford Windstar 1999 - heater/airconditionar defect
not sure what u mean by a crack in the unit, what unit? this problem at my Ford dealer is most often caused by a defective front temperature control blend door motor, a very expensive fix.
Mar 16, 2009 | 1999 Ford Windstar
DESA ReddyHeater R55BT will not stay lit. Sometimes it will huff and puff and blow a cloud of black smoke and quit; other times it will light for a moment or two and go out; others still it will run 2-3...
this unit has neither flame sensor or oxygen sensor.it has an photo cell in it.look at the plate that is on the back of unit.that is the air pump filter cover.if you look very closly you will probbaly see tiny cracks around one of the holes,either the adjuster or the plug.these covers crack all the time and they are not noticeable.when they crack it changes the air pressure and the unit doesn't work right.let me know and i hope this was helpful to you.
Feb 24, 2009 | Reddy Heater RLP100 Portable Forced Air...
Fan runs backwards forces flame to blow back into heater instead
cracked heat exchanger not cheap replace unit ur motor just doesnt change rotation on its own
Jan 13, 2009 | Reddy Heater RLP100 Portable Forced Air...
DAYTON 4LX48 HANGING HEATER
Exhaust is restricted or crack in heat exchanger. Get someone to look at it!
Feb 13, 2008 | Dayton (4LX41) Heater
Lakewood LAKQTV22 Utility Heater Logo
171 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
