Question about Compaq Presario C700T Notebook
Hard Drive will not boot in Compaq Presario C700
I have a Compaq Presario C700 and the hard drive went bad. I got another hard drive. I was unable to reinstall Vista on it using the Compaq. It would say the file header checksum does not match the computed checksum. I borrowed a buddies HP and put the hard drive in that an was able to reformat it with Vista and it works. I swap it back to the Compaq and it still gives me the file header checksum does not match the computed checksum. I can go into the BIOS and check the hard drive and it says its all good. Does anyone know what can solve this problem?
  • Compaq Master
  • 32,281 Answers
BIOS checksum errors occurs when either the BIOS chjp is faulty or most likely the BIOS battery is nearly flat and the stored info changes and doesn't match the checksum info.
Replace the battery with a new one, leave the battery out for 1/2 hour before inserting the new battery. The BIOS will be reset to the default settings, you need to configure it again eg, datr and time etc.
Posted on Feb 23, 2009
My compaq presario c700 will not boot and it's saying that there is no bootable device, insert boot disk and press any key, however, i do not have a boot disk
Your Compaq did not detect the hard disk, that is why it is asking for a bootable device such as a boot floppy disk.
Check the BIOS configuration to see if the hard disk is detected, if not then re-seat the hard drive and boot up the Compaq again.
If it still does not boot up, then the hard disk is probably faulty.
To get the Compaq operating again, replace the faulty, install Windows operating system on the new hard drive, plus the Compaq's device drivers and your programs.
Jan 09, 2011 | Computers & Internet
My compaq presario x-1000 hard drive light and dvd rom light flashes. Won't boot up.
Try disconnecting the harddrive from the case and then place it back in. if that doesn't help you may have a faulty drive, hows warranty? Compaq / HP would fix it for you free if you still have warranty.
let me know.
Thanks,
Ekse
Oct 31, 2008 | Compaq Presario X1000 Notebook
Compaq Presario C700 sled off bed. Getting error
Your hard drive came loose i would take the cover off your hdd and remove and then place it back in should fix it but if not then you need a new hdd.
Oct 24, 2009 | Compaq Presario 700 470024-192 Notebook
I have a Compaq Presario 2715US. Started having
The problem maybe a loose electrical connection with the RAM modules and hard disk. Re-seat the RAM modules and the hard disk.
If the problem persists then the hard disk maybe faulty.
To test the hard disk, remove the hard disk and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If this computer has trouble seeing it as an external hard drive and unable to open the folders and files then the hard disk is faulty.
Then the hard disk needs to be replaced in the Compaq and Windows XP needs to installed on the new hard drive and the device drivers and programs.
Oct 12, 2009 | Compaq Presario 2715US Notebook
I have a compaq presario x1000 that wont let me get past the logo. It was working fine one day, but then I shut it down. The next morning I booted it up it the computer never went past the Compaq logo.
It is likely that the hard drive is bad or a memory issue. I would start by removing the hard drive and see if it goes past the compaq screen. If it does then you know what is wrong. If not message me and will walk you through the next step
Jun 30, 2009 | Compaq Presario X1000 Notebook
Compaq C700 XP Downgrade HELP!!!
When you first start the computer, go to the BIOS (usually press [Delete]) and make sure the hard drive you are installing Windows XP to is the second or third boot device. If your CD drive is IDE and your hard drive is SATA you may have a problem in the BIOS of not being able to cross from IDE to SATA.
Jun 10, 2009 | HP Compaq Presario C700T
Install xp in compaq presario c700
The hard disk may be set to Enhanced AHCI SATA mode. Look for Legacy or IDE mode setting in BIOS menu options.
XP SP2 does not recognise Enhanced SATA mode hard disks.
see http://www.mydigitallife.info/2007/10/23/windows-xp-setup-could-not-detect-and-find-any-sata-hard-disk-drive-on-ahci-mode/
You may be able to use NLite to make a CD which has correct SATA drivers.
Nov 23, 2008 | Computers & Internet
Hard drive not working
If you're sure about your issue, you can get one hard drive on the internet and replace it.
check here:
http://www.comptick.com/cq-c7sa-160.html
Oct 27, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario C700T Notebook Logo
404 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
