Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker and now water dispenser does not work
First just ice maker did not work,started by checking dual water valve both sides at valve both were puting out lots of water replaced ice maker, ice maker made one tray in two days and the water dispenser still worked. I doubled checked the water valve again no water to ice side so I replaced the dual water valve and now the water and ice dispenser does'nt work, I then put the old water valve back on to see if the water dispenser would go back on but it still does not work please help I have spent 200 bucks already.
ge model side by side pss29mgmbcc
  • 74 Answers
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Posted on Feb 26, 2009
There are two sides to the Dual Water Control Valve. The ice maker side is still working but the water dispenser side is possibly defective. Sea Breeze Model Number?
Magic Chef Refrigerator Parts
Dec 15, 2013 | Magic Chef Refrigerators
Ice Maker working, but water not dispensing
There are two sides to a dual water control valve. One side fills the ice maker and the other side is the dispenser. If one side goes bad you will need to replace the whole dual water control valve. If your model is the GSL22JFXLB your replacement is the=> WR57X10032 Water Inlet Valve
This part is found on the rear of your refrigerator near floor where the water from your home hooks up to your refrigerator, Thanks Sea Breeze
Mar 08, 2013 | GE GSL22JFXLB (22 cu ft) Side by Side...
GE bottom freezer ice maker not working
Remember there are two sides to a dual water control valve, the water to dispenser side and the side that feeds the ice maker. Replace the WR57X10094 Dual Water Control Valve and I think you will be good to go on ice, Thanks Sea Breeze
Jul 02, 2012 | Refrigerators
No water from dispenser but ice maker working
You have two sides to the water control valve and it is most likely the dispenser side of your WR57X10051 Dual Water Inlet Valve I will be here should you have more questions, Thanks Sea Breeze
May 20, 2012 | GE Profile Arctica Stainless Steel Top...
GE Fridge water dispenser working but not the ice
Yes you most likely have a defective dual water control valve. Look around the inside of the refrigerator for a model number.
Click here=> For most locationsSide-By-Side
  • Top Freezer
  • Bottom Freezer
    Once you find the model number I will be able to tell you what part number the dual dual water control valve is or if your ice maker assist you in testing ice maker. If ice Maker is empty try filling with tap water to top edges of ice maker, allow water to freeze and if the ice drops into the ice bin but does not refill with water automatically I would say that the dual water control valve will need replaced. If your ice maker has old shrinking ice from a few days ago it will point to an ice maker problem.
    Thanks, Sea Breeze
  • Feb 10, 2012 | GE Refrigerators
    Water dispenser & ice dispenser stopped working
    The ice maker not working: ---
    Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
    Click this link below to troubleshoot the problem: ----
    The water line is clogged or water dispenser valve is blocked.Click this link below for troubleshooting:---
    This will help. Thanks. Helpmech.
    Oct 31, 2011 | Refrigerators
    I have a Kitchenaid model ksrk25 that the water dispenser does not dispense water and the ice maker that was working has stopped making ice
    It is rare that both sides of the water control valve go bad at the same time, but possible. I will need someone to examine the dual water control valve on rear near floor on the back of your refrigerator. Click here for a=> KSRK25FVBL00 Parts Manual Test the dual water control valve with a multi meter set for 120 VAC and place the probes into the wires that attach to the dual water control dispenser side and have someone press the water dispense control in fountain. With the dispense water pressed look for voltage on your multi-meter. Use care not to touch probes or bare wires to prevent getting shocked while testing. If you do not already have Adobe Reader on your computer click here first=> Adobe Reader X (10.1.1) You can also check the water control valve for ice maker by testing the ohm value first by removal of the front cover on ice maker and then placing the test meter probes in to the N and V opening You should get 150 to 350 ohm's of resistance. Also if your ice maker is dry and has no water then fill with tap water and then allow to freeze. If Ice drops into ice bin and then does not refill with water will point to repacing the water valve. If the clip is not below this post click here=> Broken Ice Maker Repair You also can find parts and user manuals by clicking HERE Sometimes the ice maker is the problem with the water control valve not working on the ice maker side. 2198597 Ice Maker Assembly Watching the clip is really a great way of explaining how to test ice maker and replacing water control valve if needed. If helpful please rate this solution and if you have questions I will be here to assist you, Thanks Sea Breeze
    2315534 Dual Water Control
    Oct 28, 2011 | KitchenAid Superba Architect KSCS25INSS...
    Ice maker has quit working where do I begin?
    Aug 28, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Water in door but none to ice maker-why
    couple of things to check make sure there is no obstruction where the fill tube comes into the icemaker... if ice builds up in plastic tube it will not allow to come into ice maker... if there is ice there most likely the water valve is not closing all the way... these are normally dual water valves meaning one solenoid goes to ice dispenser /water dispenser and the other works the ice maker good luck
    Dec 31, 2010 | KitchenAid KSCS25FKSS Side by Side...
    My roper side by side ice maker does not work. I replaced the part on back which directs water to the ice maker and water through the door. I get water through the door, but ice maker still does not work....
    Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
    See if the ice maker starts working when it dumps the ice.
    Sep 28, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
    GE (PSS26MSRSS) Side by Side Refrigerator Logo
    428 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
