Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista HomeBasic 9980286710 PC Notebook
Problem for Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista...
Magic Jack Sound breaks up and you can not make or receive calls.
By sublime_1982 on Feb 22, 2009
We have Windows XP
Solution #1
posted on Nov 08, 2009
Not Rated)
Rez1
Rank: Apprentice
Rating: 0%, 0 votes
I had this problem and started doing every hack that I could find on the internet. I have a neighbor across the hall whose Magicjack worked fine, and so I plugged my Magicjack into his computer, and it worked fine. So, I knew my computer had the problem. After a month of hacks and fixes, to include reinstalling the operating system, I found something that worked! It has to do with the paging file on your computer. I partitioned my hard-drive and put the paging file on its own partition. I also installed a second hard-drive and gave the paging file a second partition to go to. After doing this, my computer runs much better and the Magicjack works like a charm. In the last 3 months of using it, I haven't had any problems. This solution also reduces the problems with fragmentation of your paging file and the overall memory.
Was this helpful?
Yes
No
Solution #2
posted on Jul 16, 2009
Not Rated)
deschilz
Rank: Wiz
Rating: 92%, 12 votes
Can be several things. All I can suggest is that you have to eliminate as many variables as possible. I had much the same problems and now my install is solid (see my setup below).
1. What type of phone are you using? I first tried a cheap wired set with a 20 foot phone cable. This caused several calling and receiving problems. Get a decent quality phone (wireless or wired) and keep the cable no longer than 6 ft.
2. What else is running on the PC? try killing everything else to see if it is a resource issue. If works, start your other things one at a time to see what the conflict is.
3. Is your internet connection working well? Get into your router if you can and check status. If you have doubts, have your ISP check it out and tell them you are doing VOIP. Web surfing is is far more forgiving the VOIP. You, of course, need a high speed link for any VOIP to work reliably.
4. Check with Magic Jack on the web to see if your unit needs a firmware upgrade. Not sure when you got yours but they have had a few issues so it may be worth a shot.
My set-up so you have a reference:
-Magic Jack at latest revision
-XP home, SP3 with 512mb of ram and running Magicjack + zonealarm firewall. (I bought a used Dell Desktop for $150.00 off eBay and it runs 24x7 for MagicJack)
-Two Vtech wireless phone sets (WalMart) hooked up with a home-made "y" cable that is 5 ft. long. Gives me 4 wireless phones. I do not use the PC with a headset so don't know about this functionality.
-DSL: 608 up speed and 3553 down, link status constant "up" and "0" errors. Also ran at lower DSL speeds without issue but link status (up) and errors (zero) are CRITICAL.
- I forwarded my Magic Jack number to my DSL required land-line. Works great and I can use my existing caller ID, answering machine and call blocking gizmos without a problem.
Hope this at least gives you a reference. I just renewed for five additional years of Magic Jack and it works as well as my land-line ever did
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 3680
Questions and Unsolved Problems for Acer Aspire 3680
Do you recommend Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista HomeBasic 9980286710 PC Notebook?
Answer
Answer
Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista Acer Aspire 3680 will not boot up Answer Acer... (More)
Answer
Hello Is there a way for me to down load recovery disc for Accer 3680-2682.
Answer
bootmgr missing on a acer 2930z. Havve no reboot disc etc. plz help...
Answer
isatap #14, 15,16 is flaged on the computer. what does that mean...does it have anything to do with... (More)
Answer
i have problem with my ctrl key it is always pressed example when i press only (F)then its open find... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 3680...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
