Question about Sony MDS-JE520 Mini Disc Player
Start button not working standby light staying
Even when i switch of power and switch back on problem persists start button not working standby light still on
  • HW_Dude
    HW_Dude May 11, 2010
    Can you describe the problem in more detail please ?
    Cheers
  • Sony Expert
  • 509 Answers
The switch is for 'REC' 'Standby' and "PLAY".
If you leave it switched to "Play" and pull the plug and push it in to the wall receptacle (mains) it should start playing after a few seconds delay. The same for "REC". You use a timer unit on the power cord for those.
If you have the switch in the middle position and plugged-in, you should have a tiny Red LED illuminated. Push "Power" and it should start-up and be ready to use in a matter of a few seconds.
Posted on Sep 01, 2009
Preamp stuck in standby mode
a flaslight bulb and batteries and couple of wires can be used to make a continuity tester.and also pls check the small pushbutton(power button)try the remote if theres any
Feb 04, 2014 | Adcom GFP-710 2-Channel Amplifier
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
The screen and standby light dont work but touch sensitive buttons still beep
Look for any loose contacts in power outlet, RC Jack, cable and connectors. In order to ensure, it is not caused by the input device, connect a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 22, 2012 | Televison & Video
I have a pioneer Pro 200 and have had it for a dozen years. I have an HD in my office and the picture is so good and bright on the Pioneer I just cannot bring myself to get rid of it. The TV blinks off...
Im going to guess that if you try turning it on, sometimes you hear a "click" and nothing then the problem persists over and over until it finally turns on? If so, it's a problem with the power that "jumpstarts" the screen. Worn out capacitors on older models don't hold the necessary charge it takes to "start" the inverter that powers the screen. Once those start to go, it's usually bye bye for the tv. That is IF this is your problem. Let me know. Sometimes it makes hissing or cracking noises along with it. hope this helps!
Jun 11, 2012 | Pioneer PRO-200 60" Rear Projection...
Samsung HLS5687W XAA will not stay on
You might have the problem with your standby processor on it, that needs samsung technicians.
May 03, 2017 | Samsung HL-S5087W DLP TV
HK AVR130 Standby Button not working
I am experiencing a simular problem; amber light stays on ; no other lighting appears. this occured after leaving the avr in standby mode for a long time. I even tried to reset the unit as stated in the last page of manual after the trouble shooting advice - still no response - good luck!
Sep 18, 2008 | Harman Kardon AVR 130 Receiver
50"plasma
so you got the audio working correct? Sounds like it may be going into a protection mode of some sort now. I would try leaving it unplugged overnight and try again the next day and see if it starts working
Apr 30, 2008 | Televison & Video
SHARP 29" TV switching off to Standby
have you tried changing the batteries just to elimate this problem
change them
sometimes if the batteries are low in electronic devies, they send a wek signal to its receiver (your tv),
your tv gets confused and then switches itself to standby
if you have changed the batteries and this problem still persists
it can only then be th PSU or power supply unit, take it to your local tv repair shop of mastercare somewhere like that, its going to be cheaper to get it repaired than replacing the whole tv
PSU'S generally 20 to 50 pounds depending on model
don't deo it yourself though unless you've got a capacitor discharger (or a nice 25KV will be on its way to your body)
hop this helps mate, let me know how you get on
Nov 10, 2007 | Televison & Video
Black Screen / Computer Stays in Standby Mode
Completely remove the battery and unplug the power cord for a few minutes. Reinsert battery and power up. You can also hit F8 when starting and see if you can boot into safe mode.
Sep 06, 2007 | HP Compaq Presario V2000 Notebook
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Sony MDS-JE520 Mini Disc Player Logo
206 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
