Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
Posted on Feb 22, 2009
Hotpoint w440 washer/dryer keeps repeating cycle load?
I was just wondering if anyone else had had the same problem. I put the washing machine on this morning before i went out and when i got back hours later, the load was still going. its almost like it jus keeps repeating itself over and over until you cancel it?
i just cancelled the cycle and turned the machine off. Any idea what this could be or how to get around this?
many thanks
  • Anonymous Mar 10, 2009
    keeps repeating cycle and dryer has stopped working,
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
977
Points
Hi there, I've got a Hotpoint Aquarius washer / dryer and this has just started happening to me - it seems to get to the end of the cycle then repeat itself. However, I do not seem to be able to cancel the cycle, or am I able to switch it off. It's been going for about 4 hours now. Any ideas?
1helpful
My hotpoint aqaurius WD420 is not drying.
Could be stat or heater .Remove the top cover, and you will see the heater manifold on the right side of washer drum.
The element and stat/s are located on the top of the manifold box.
You willneed a meter to test with, also check for broken wires.
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Wash programme won't finish
this happened to my machine, I had to get a repair guy out in the end and he said it was the heating element had gone and that was why the cycle wouldn't move on as it could not heat the water to right temp.
he charged me £60 to repair and for part, still a lot cheaper than hotpoint though. try to get a local guy, hotpoint charge £100 basic.
Hotpoint WD420 Washer/Dryer - Not completing cycle
I WOULD FIRST CHECK THE COLD WATER VALVES ONE COULD BE INTERMITTEN
4answers
Hotpoint wd62 leaking from the drawer
Hi, check the electrict valve winding busted hot and cold.
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
2answers
Problem with our washer/dryer
sump/filter is blocked instead of flushing on dry cycle is filling as not pumping well. ring hotpoint to reorder pts cheaper then anyone
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
