Question about HP (158800-001) for Compaq Presario 1246, 1247, 1277, 1279 Cooling Fan
I have a Gateway Mx6440 Laptop and et CPU FAN error upon boot. afte w while i try spinning th efan and it starts working, i belive it is the heat sink that is defective but where can i find the proper fan assembly? thanks Red Wings Fan also i have an extra Toshiba Laptop, are the Toshiba Fans interchangable with the Gateway to save me some cash? Thanks again
"Turn off computer and unplug power cord. <br>Disconnect all external devices. <br>Remove the battery. <br>Press power button and hold for 10 to 15 seconds. <br>Plug power cord back into computer and press power button. <br>Check front panel LEDs (lights) on bezel (front face) or optical drives and listen for power supply fan. <br>If LEDs are on or power supply fan starts spinning, watch for boot screen on monitor. <br>If computer begins to start, turn it off. <br>Reconnect any external devices. <br>Press the power button and make sure the computer starts.
Please save this steps and go through that. If in case you require further help, you need to contact Answers by Gateway department which is a paid support. The phone number for Answers by Gateway is 1.800-237-6483. Or please consider contact with a local technician for a detailed troubleshooting."
worked for mee!! good luck
Posted on Oct 17, 2009
Hello there... i just had that same problem but got it figured out.. it was a really easy fix, but dont know if your problem will be the same... what i did was open up the panel covering the fan on the underside of the come and then unscrewed the bronze thing connected to the fan unplugged it then took the actual fan covering off and found a small amount of lint/dust that had accumulated there and was too much for the little motor to keep spinning... so yea.. you can give that try! might work... removing that lint completely fixed my comp... good luck
Posted on Jun 18, 2009
Gateway m465e laptop will not turn on
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Mar 13, 2013 | Gateway M465-E Notebook
Nv laptop overheats
Oct 15, 2012 | Gateway M6307 Notebook
My gateway laptop automatic power off ? way
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 26, 2012 | Gateway Computers & Internet
Gateway m255 laptop cpu fan wont let me boot up
open your laptop up and make sure the fan cabels are in correctly if not push them in if that dosen't work get a new fan for it
Jun 15, 2012 | Gateway M255-E Notebook
IBM R51 laptop when start the laptop it canot boot and error display thermal sensing error
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Jul 05, 2011 | IBM ThinkPad R51 Notebook
My gateway mx laptop gets so hot you can fry an egg on it and the fan runs all the time and shuts down when its hit its hottest what can be done about this i have to shut it off or the fan will still...
Mar 26, 2011 | Gateway Computers & Internet
Laptop is heating up and then shutting off
Feb 07, 2011 | Gateway 7510GX Notebook
My laptop turns off every 30 min.
The laptop could be over heating and causes the CPU shuts down (ie thermal overload) and won't boot up again until it has cooled down. If this fault is not fixed the eventually the CPU will fail.
This fault could be caused by a faulty fan or the fan and heat sink assembly is clogged with dust.
Check the CPU fan to see if it spins freely, if not them replace the fan.
If the fan and heat sink assemble is clogged with dust then remove this dust and clean it with a can of compressed air.
Dec 06, 2010 | Gateway Computers & Internet
Laptop keeps shutting off by itself
When you encounter about this issue this is overheating problem maybe the CPU fan is not spinning and faulty already, you need to check the CPU fan and replace a new one.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Oct 08, 2009 | Gateway (60.44K08.001) Laptop Heatsink
Gateway MX6440 heat sink failure
Check your BIOS settings when the PC starts, this can be accomplished by pressing F2 or Delete (depending on your model) when in your Bios check the power settings for CPU options such as SMART CPU and other variations. Most newer laptops and desktops have temp sensors that regulate fan speeds, thus saving energy and prolonging the lifespan of your fan, let me know if this helps you out
Sep 29, 2009 | Gateway MX6440 Notebook
HP (158800-001) for Compaq Presario 1246, 1247, 1277, 1279 Cooling Fan Logo
1,473 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
