Question about Autodesk AutoCAD LT 2008 - Upgrade for 5 Users Upgrade Version for PC (05728-051452-9315)
AutoCad R14 to Vista - bab-Mem-Pointer error message
This version of AutoCad worked perfectly in NT - now that I upgraded PC's and have Vista - when I load the app - it gives me the above error message, and won't even OPEN autoCad. This is a program my husband needs to use daily - anyone have a solution??
Anyone can please help me how to solve my problem is can't run autocad r14 with windows 7 mem.bad pointer?
Posted on Feb 29, 2012
    Problem Solver:
  • 13 Answers
Apparently, autocad is not compatible in vista.. Might as well, go back to wndows xp.. Please see the required specs to run R14
Posted on Mar 31, 2010
  • vladi29a Mar 31, 2010
    Problem Solver:
  • 12 Answers
You are still using AutoCAD R14? If you are that might be the problem. If you are running Vista, then AutoCAD R14 might be too old of a version to run. You will probably need to upgrade to a newer version of AutoCAD. I know this isn't a solution, but I am just trying to look at it from a different point of view. You can also go to autodesk.com and join their discussion groups. It is free and you can post questions. You usually get a fast response with an answer that really helps. I will do a little more research and add more when I get a chance. Good luck and I hope that I helped.
Posted on May 11, 2009
  • 1,606 Answers
Did you install on vista or just upgrade windows? It should work or give an error of some kind if installed. If you upgraded vista then you need to reinstall so vista can find certain parts of the program.
Posted on Jul 09, 2009
I am trying to install AutoCAD 2004 on my new computer with windows 7 and wont install. Any ideas?
AutoCAD 2004 and Windows 7 are NOT compatible. You will need to upgrade to AutoCAD 2010 either 32-bit or 64-bit. Even with the upgrade, there are known limitation issues.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14056444&linkID=9240617
Jan 03, 2010 | Autodesk AutoCAD 2004 for PC
Unable to load autocad 97 on windows vista
I don't believe Autocad will work at all on Windows Vista.
The only other solution I can think of is to download Virtual Box from http://www.virtualbox.org/
You will need to have an XP cd to install, and basically you will be installing an XP virtual machine, at which time you can then install Autocad 97 onto that virtual machine.
Hope this helps!
Jul 19, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
Error in Palm Desktop on PC
You need version Palm desktop v6.2 (not v4) to run under Vista. If you have the 64 bit version of Vista you will have to use Bluetooth to transfer data, not USB. Enjoy and please rate this post.
Mar 21, 2009 | Palm Tungsten T3 Handheld
Windows vista will not open autocad 2004 after being loaded
All you need do is got to autocad website and download the autocad lockeds1. its a patch it works for pirated autocad as well.
Mar 02, 2009 | Autodesk AutoCAD 2004 for PC
Help me for this problem please
Hi Hamzawork Autocad 2004 is designed to be used with Microsoft Windows XP (Professional, Home Edition, or Tablet PC Edition), Windows 2000 Professional, or Windows NT 4.0 (SP6a or later) therefore I'd suggest to run your Autocad 2004 using Compatinity Mode --> Right click on the program icon--> properties-->Compatibility--> select one of the versions above
Nov 07, 2008 | Autodesk AutoCAD 2004 for PC
How to Autocad LT 97 install to VISTA PC
I have autocad 97 and want to install it on windows 7 can you help please
horriel
Jul 19, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
AutoCad LT 2006 incompatible with Windows Vista
some of the older versions of autocad does'nt tend to work in vista.try installing autocad 2008 or 2009.it is recently released and well compatible with vista.REMEMBER, if u r using it for architectural purposes,try downloading autocad architecture 2008.it is especially made for architects.try downloading it on torrentz.com
Jun 12, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Conflict with Autocad 2004 (using Windows Vista)
May 23, 2008 | Autodesk AutoCAD 2004 for PC
Windows Vista and Autocad r14
try this thread from autodesk it is having solution
Feb 02, 2008 | Microsoft Windows Vista Ultimate Edition
Autodesk AutoCAD LT 2008 - Upgrade for 5 Users Upgrade Version for PC (05728-051452-9315) Logo
729 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
